Old 29th September 2010, 02:13 PM   #1 (permalink)
Jon
tokick4
identify gearbox
I thought I had a un1 box but the tag on the rear has across the bottom 001339 and then around the sides up over the top starts with c NG9003. These numbers are on a metal stamp tag bolted to the end. Then I found a number on the housing at the tail that had 7700598829. Can any one help me identifiy this because I need to make an adapter to mate to a bmw v12. And can anyone give me the information in what I need to do this with.
tokick4 is offline
Old 29th September 2010, 04:05 PM   #2 (permalink)
pdprice_2000@hotmail.com
GT40: Southern GT 40
Re: identify gearbox
look at this link on ebay it has a bit of information
RENAULT 21 GEARBOX (CODE NG9001) 2.1 TD FROM A 1992 VEHICLE
RENAULT 21 GEARBOX (CODE NG9001) 2.1 TD 92 on eBay (end time 18-Oct-10 13:33:08 BST)
pdprice_2000@hotmail.com is offline
Old 29th September 2010, 06:17 PM   #3 (permalink)
simonjrwinter's Avatar
simonjrwinter
I Have No Life
Will a UN1 stand up to the torque of a BMW V12 engine?
I would have thought a ZF or G50 would have been a safer bet.
Simon
Currently GT40-less
simonjrwinter is offline
Old 30th September 2010, 12:47 AM   #4 (permalink)
LastPago
France
GT40: GTX-LM
A standard UN1 has high risk to break above 40 mkg of torque. This considering the Yield trength curve of the steel used and the different shaft sections. Obviously this value may vary according to the resistance the car offers to the force moment (weight, tyres friction, air resistance with speed etc...) and also by the heat inside the gearbox. Anyway keep this number (40) as a pivot for a standard use of the gearbox. Below 35 it is ok, 35-42 is the high limit, above you need upgrades.
A NG gearbox is the poor sister of the UN1, weak gearbox even if at first glance it loks like a UN1, it is really weak and clearly not safe for the use you plan to do.
So better to sell it and buy a real UN1/UN5 if you want to go with Reault or any other brand according to the recommendations made here
Stephane
LastPago is offline
Similar Threads
Help me identify what I've acquired please smashedheadcat All GT40 18 25th May 2010 03:09 PM
Can Anyone Identify This Chassis???? Mark McCaughran GT40 Tech - Chassis,Brakes,Tires,&Wheels 8 8th July 2008 08:02 AM
Who can identify this car for me? trojan007 The Paddock 7 8th February 2006 11:03 PM
Help identify hojnacki The World Market - Share Parts, Sources, and Reviews 5 16th December 2004 07:08 PM
Can anyone identify these? tfreeland All GT40 9 25th November 2003 03:13 AM
