Ford Modular Engine
I am building a Southern GT using the FORD Mustang Modular engine. It is the 4.6 liter and is very big engine, I intend to use the Renault 21 gearbox. Has anybody fitted this engine and gearbox combination. If so what clutch housing did you use. Were you able to keep the standard flywheel, and what clutch did you use.
Thanks for any help, once past this part I am sure it's plain sailing (not).
Don, here's a cross section pic which may be helpful for comparison. Yes, that's a big engine dimensionally speaking.
I believe some folks in Aus/NZ have fitted that engine successfully, and done so (at least partly) due to emissions compliance reasons
Thanks guys, I have now found that Mark, late of MGD is now doing the very part that I require, but thanks for the input.:laugh:
