01E Reverse Switch Connector
Renato
If you have a Audi 01E and looking for the reverse switch connector (plug) it is a Bosch EV1 for Fuel Injectors. EBay has plenty of them, possibly local stores also.
I figure I'll put it out there in case someone hits a snag during wiring.
Renato
Renato
The 01E can have one of three different reverse switch connectors.
Renato
Hi Scott,
Thanks for the clarification. Does it depend on serial number or is it random?
Can you identify the other two?
Renato
Hi Scott,
Renato
It's by chassis number but for the most part they are the connector you mentioned. There is also a two pin D shaped connector and a 3 pin which has both a N/O and N/C switch. I've only seen a couple of the latter so they are very rare.
