Go Back   GT40s.com > >
Thread Tools Display Modes
Old 17th December 2017, 11:09 AM   #1
Norcoastal
GT40: None
944 Turbo with a Coyote?
I致e been doing A LOT of reading. I知 picking up my chassis in January and I知 planning my build.
Right now I知 thinking coyote engine but I知 not 100%. I知 researching what transaxle to use and the consensus is an Audi, Porsche or ZF.
ZF痴 are too expensive and the Audi 016痴 are scarce. I read somewhere that a 944 turbo transmission is a good option.
Does anyone know if that would match up to a coyote engine? I believe these transaxles are hydraulic also which is what I want.
Any thoughts?
Norcoastal is offline   Reply With Quote
Old 17th December 2017, 11:17 AM   #2
Norcoastal
GT40: None
Re: 944 Turbo with a Coyote?
Because I知 still learning, I wonder if the number that is stamped on the 944 Turbo is the same as the Audi 016. I wonder if Porsche and Audi got their trans from the same distributor?
Old 17th December 2017, 11:52 AM   #3
Walt Williams
GT40: CAV GT40
Call scott dewitt at advanced automotion. He will build a audi 01e that will handle 500 hp.. Mine handles 470 hp just fine... A good product from a good man.
Walt Williams is offline   Reply With Quote
Old 17th December 2017, 04:36 PM   #4
Eric Martin
2 Tenths
GT40: none now, planning one
The 944 transmission will not bolt up as it has no provisions for a pilot bearing or throwout bearing in the transmission. I would recommend the Boxster S 6-speed. They are getting very affordable and can handle up to 500 HP.
Eric Martin is offline   Reply With Quote
Old 17th December 2017, 05:30 PM   #5
Norcoastal
GT40: None
Boxster S 6 speed. I’m on the lookout. Thanks Eric, ignore my PM.
Old 17th December 2017, 05:37 PM   #6
Norcoastal
GT40: None
Will the 5 speed work or only the 6 speed.
Old 18th December 2017, 08:49 PM   #7
Eric Martin
2 Tenths
The 5 -speed is rather weak. The 6-speed is much better.
Old 19th December 2017, 02:11 PM   #8
Norcoastal
GT40: None
I have to assume that the Audi 5 speed is stronger?
Old 19th December 2017, 09:20 PM   #9
Eric Martin
2 Tenths
same transmission.
Old 19th December 2017, 09:41 PM   #10
Norcoastal
GT40: None
I just found out that the chassis I’m buying is designed for a Porsche 996 or 997 trans.
Old 20th December 2017, 01:22 AM   #11
Eric Martin
2 Tenths
The 996 is almost identical to the Boxster 6-speed except it is a rear engine rather than mid-engine design. It must be run upside down and is mounted on the end like a G50 rather than from the side of the housing like the Boxster is.
Tags
audi, coyote, engine, i知, turbo
Forum Jump
