Go Back   GT40s.com > >
Thread Tools Display Modes
Old 13th February 2018, 02:03 AM   #1
Kim Haun
GT40: RCR GT40
Porsche transaxle starter fitment...
I found some useful info on this site on fitting a starter for the Porsche transaxle. I have a stock Bosch starter but as many of you know the solenoid gets in the way of the Horshoe in the RCR chassis. Hi Torque says they have a starter that will work for my application but I am bulking at the $600 price tag. Is the Hi Torque starter a much better starter than the stock Bosch unit? Would I be better off just re-locating the ears on my stock starter to clock the solenoid out of the way? A bit of a project to do, it seems, but not impossible. Does anyone have the best(in their opinion) work around for this?
Kim
Kim Haun is offline   Reply With Quote
Old 13th February 2018, 11:41 AM   #2
Joules5's Avatar
Joules5
GT40: ERA MK1 Gulf
Re: Porsche transaxle starter fitment...
A number of manufacturers offer a 'clockable' starter that allows rotation in the mounting or an adapter to achieve same for a lot less than $600. That is not to say the Hi Torque is not a good starter.
ERA Gulf GT40 #2041
Pantera's '81 GT5 & '74 L
Swift 008 Formula Atlantic
Ultima CanAm
Joules5 is offline   Reply With Quote
Old 13th February 2018, 06:47 PM   #3
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
If you take a look at my build site you can see the route that I took. It was a lot of screwing around, but clockable starters were not available at the time.
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 13th February 2018, 10:22 PM   #4
Adam H
Take a look at page 4 of my build. Starter part number is IMI-101NL.
Adam H is offline   Reply With Quote
Old 14th February 2018, 07:54 AM   #5
flatchat's Avatar
flatchat
GT40: RCR T70 spyder
Wink Re: Porsche transaxle starter fitment...
RCR T70 similar chassis
Unfortunately -"Titus" the god of spend thrift doesn't apply here :-)
Porsche transaxle starter fitment...-lolarcr-015-jpg   Porsche transaxle starter fitment...-lolarcr-013-jpg
The Trans Adapter Man
flatchat is offline   Reply With Quote
Old 14th February 2018, 04:23 PM   #6
GT40Graham's Avatar
GT40Graham
2 Tenths
GT40: Scratch built.
Hi Kim,
When I first built my car I used a Porsche starter. I had some new lugs welded onto the starter mounting plate which allowed me to rotate the starter and have the solenoid out of the way. It wasn't a massive job.
Graham. www.gt40.org.uk
GT40Graham is offline   Reply With Quote
Old 14th February 2018, 09:30 PM   #7
Kim Haun
GT40: RCR GT40
Thanks, Joules5. If you have any names of these manufactures, please let me know.
Kim
Old 14th February 2018, 09:37 PM   #8
Kim Haun
GT40: RCR GT40
I'll happily spend the money for a better starter, but I've read that some have been unhappy with the aftermarket starters and prefer the Bosch unit. What say you flatchat? Is the starter you show in the photos a better starter than the Bosch unit?
Kim
Old 14th February 2018, 09:39 PM   #9
Kim Haun
GT40: RCR GT40
Originally Posted by GT40Graham View Post
Hi Kim,
Thanks Graham! Do you still run the Bosch or did you find a starter you liked better?
Old 14th February 2018, 10:32 PM   #10
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
The Bosch unit is a fine piece. What I have done in the past is to re-clock the starter to clear the chassis . There is plenty of material in the bellhousing casting to re-drill one of the mounting holes in a new location. The other mounting hole can then be drilled into the billet adapter plate provided by RCR and a simple spacer fabricated to bolt it solid. Works like a champ.
Ron
RCR GT40 MK1#14 (SOLD)
Superlite GT-R #14
DeTomaso Pantera#1889
Pantera1889 is offline   Reply With Quote
Old 15th February 2018, 03:10 AM   #11
Kim Haun
GT40: RCR GT40
Hi Adam, Have you actually used this starter yet? Does it engage with your flywheel? I saw your build a few weeks ago and based on it I ordered the same starter, 101NL, $295...nice starter, good price. But when I received it compared it to the Bosch starter I have, and know works, it didn't have nearly the reach needed to get to the flywheel...like almost 2 inches short. I called the folks at Hi Torque(who have been really great to deal with)and showed them photos of the Bosch starter I had, they said they had the starter I needed but it was $600...a bigger more billet encased pinion that had the strength to handle the much longer reach. And that brought me here. I have a Tilton flywheel and clutch that puts the ring gear in the stock Porsche position. Unless your clutch and flywheel puts your ring gear much deeper in the bell housing, I don't believe that starter will work.
Kim
Old 15th February 2018, 03:25 AM   #12
Kim Haun
GT40: RCR GT40
Ron
And we have a WINNER! Of course! Simple, smart, easy! Nice Ron...thanks!
Kim
Old 15th February 2018, 04:56 AM   #13
GT40Graham's Avatar
GT40Graham
2 Tenths
Hi Kim,
No, I don't run the Porsche at all, now on a ZF. I'll see if I can dig out the starter and send you some photos.
Graham
Old 15th February 2018, 05:20 AM   #14
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Ron
I think what you did was quite similar to the way I did it. However, the OEM Porsche starter could not be reclocked that far without having the the starter’s nose cone (Shield around bendix) come in contact with the flywheel and pressure plate.
Here was my solution : STARTER
Not elegant, but it worked. Note that the bellhousing was pretty thin where it had to be re-drilled so I used a 7/16” fine thread allen bolt that I cut down on my lathe to fit in from the inside.
Regards - Randy
My build site:
Old 15th February 2018, 06:35 AM   #15
flatchat's Avatar
flatchat
This is what we use with a "high torque" type starter
Porsche transaxle starter fitment...-g50-930-starter-adapter-jpg
Old 15th February 2018, 06:50 AM   #16
flatchat's Avatar
flatchat
Flywheel, clutch, ringear --this is the system that we use which works for us --anything else , you're on your own
Porsche transaxle starter fitment...-picture-200-jpg
Old 15th February 2018, 11:29 AM   #17
Kim Haun
GT40: RCR GT40
Flatchat,
I see...your setup puts the flywheel deeper in the housing than the stock Porsche position. That allows you to use the 101NL type starter...$300. My flywheel sits in the stock Porsche position so I need a longer pinion shaft. Here's a side by side of the 2 starters. Porsche transaxle starter fitment...-img_2347-1-jpg
Old 15th February 2018, 11:32 AM   #18
Kim Haun
GT40: RCR GT40
Randy, A clever solution! Fortunately my starter doesn't have the nose cone so I'm only limited by the clearance between the solenoid and the CV joint.
Kim
Tags
bosch, porsche, starter, stock, work
Forum Jump
