Go Back   GT40s.com > >
GT40 Tech - Registration / SVA / Insurance Getting your GT40 on the road!
Thread Tools Display Modes
Old 1st May 2016, 10:35 AM   #1
drewb
GT40: SGT No16
Brake bais bar lock off
Hey Guys what's the best way you have found for locking off the balance braking bar for IVA?
Thanks Andrew
drewb is offline   Reply With Quote
Old 1st May 2016, 07:25 PM   #2
kaspa's Avatar
kaspa
GT40: i wish
Re: Brake bais bar lock off
Just put a nut on the clutch end of the adjuster and nip it up.
kaspa
Steinard F5000 Steinard LMP Steinard M1B
kaspa is offline   Reply With Quote
Old 2nd May 2016, 04:02 AM   #3
Brian Magee's Avatar
Brian Magee
5 Tenths
GT40: GTD
That won't satisfy the IVA examiners, It has to be 'permanently' locked.
I have just helped someone through the test. We adjusted the brakes so that the fronts came on just before the backs by jacking all four wheels off the ground and turning the wheels by hand with the brake partly on. We drilled the nuts for the roll pins but not the bar then took it for the test . When the examiner was happy with the balance of the brakes and after a failure (which is inevitable) we took it back to the re-test with roll pins fitted. The examiner was then happy.
Brian.
GTD, 289, ZF.
Brian Magee is offline   Reply With Quote
Old 2nd May 2016, 04:35 AM   #4
saxoncross's Avatar
saxoncross
8 Tenths
GT40: Tornado
A lock nut, followed by some lock wire through a hole in the shaft will be fine. This got me through my IVA with no issues
Rgds,
Andy
Failure is not an option, but cock-ups will happen
saxoncross is offline   Reply With Quote
Old 5th May 2016, 03:18 PM   #5
GT40: Essex, UK
I agree with Andy a steel locknut will do the job, lock wire as well but not always vital. Don't forget the "don't adjust" sticker needs to be in the area
Roger Allen
Roger Allen is offline   Reply With Quote
Old 5th May 2016, 05:31 PM   #6
drewb
GT40: SGT No16
Thanks Guys a great help as always.
Old 6th May 2016, 07:51 AM   #7
Duncan
GT40: None yet!
Reading the locost forums, some examiners didn't like the lock wire / welding approach as it meant it would never be changed if it proved to be wrong in the future (!). This particular examiner preferred the locknut approach as it could be changed if it had to. Swings and roundabouts... Maybe call your local IVA centre an see what they say.
Duncan is offline   Reply With Quote
Forum Jump
