Go Back   GT40s.com > GT40 Market Place > GT40 Wanted - Parts or Services Needed
GT40 Wanted - Parts or Services Needed Looking for something, ask here!
Old 10-16-06, 10:57 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
JackW's Avatar
JackW
Magnificent Bastard
GT40: Melbourne, Aust
Rep Power: 7 JackW is a splendid one to behold
5.4L Boss Engines
I posed this question in another thread, but thought I should re-direct it somewhere more appropriate. DRB in Australia have modified their chassis to acceot the Boss 260 and Boss 290 engines. These are 5.4L engines that produce as the name suggest 260 and 290kw of power respectively.
The reason DRB have done this is mostly to meet the emissions laws in Australia. As someone who lives in Victoria which is a bit hardcore emissions wise, putitng one of these engines in is a pretty good option. However, I wouldn't have a clue as to where to source one these engines besides wreckers. Is there anywhere else that people know of that you can source one of these BOSS 290 or BOss 260 engines?
JW
Keeping the dream alive!
Original Mach 2 - From Xbox Forza
JackW is offline
Old 10-17-06, 08:50 AM   #2 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Re: 5.4L Boss Engines
Hi Jack,
It would be worth talking to Peter Ransom at DRB / GT40 Australia about this - I have heard that he is starting a new batch of GT40's, and that one of them might be a "turnkey" with the 5.4L. Given that, he will have to solve the emissions scenario, and all other builders should be able to piggy-back on his solution.
My understanding is that to get an "automatic tick" for emissions, you need to run a stock motor with stock ECU & "equivalent CAT's". The trick is to bypass all the normal "body computer" inputs so that the thing will run, & I have heard that this has now been done. PR will be able to give you the details.
You will have heard a lot of theories about how to select a car - start with the HP & transmission / body accuracy / space frame vs mono, etc.
BUT in Oz, there is one overriding factor for rego - emissions. The best starting point is a good "certifying engineer" who knows the rules - in NSW, Forum member Trevor Booth is the man. He may be able to help with Vic (or recommend a local guy), but this has to be the starting point.
Half a day's worth of consulting fees for a top certifying engineer will be the best investment you can make - without my half day with Trevor at the outset of the project, I would still be trying to get it registered.
In terms of sourcing a 5.4, Trevor, the local engineer, or Peter Ransom will be the best source of info - note that you will need the engine plus its original ECU (and all the numbers must match so that it can be proven to have come from an Aus registered car - US crate engines are a big problem as they do not generally have engine numbers, or have ones which do not necessarily prove that they came from an acceptable vehicle).
Hope this helps a bit.
Kind Regards,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 10-18-06, 10:55 PM   #3 (permalink)
JackW's Avatar
JackW
Magnificent Bastard
Cheers Peter
As per all your posts that I have read, plenty of good advice given. I have saved the post about a few scotches when things get frustrating on the build and, should I attempt a build as opposed to the turn key option, I will follow this advice religiously. Actually, I think I will just follow this advice regardless.
Anyway, re the 5.4L engines, I have been entertaining the idea of buying outright a FPV Ute and using that as a donor car. I wonder if the Tremec 6speed transmission would also fit? And those Brembos. And all the other little bits like winscreen wiper motors, power window wiring etc. Again, sounds like a questionf for Peter Ransom.
Jack
JackW is offline
Old 10-19-06, 03:17 AM   #4 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Hi Jack,
Thanks - but don't go stocking up on single-malt scotches. By the time you are battered, bruised & bloodied, a cheapie or four will have the same effect ! If you add up the premium for good scotch vs cheapies over the build process, the cheapies will let you buy a nice set of wheels & tyres out of the savings !!
Keep us posted on your decision-making process.
Kind Regards,
Peter D.
331 Windsor / GD-50
delaneyp is offline
Old 10-19-06, 07:19 AM   #5 (permalink)
Bill Haralambakis's Avatar
Bill Haralambakis
Old Hand
GT40: RF
Rep Power: 15 Bill Haralambakis has a spectacular aura about
Jack
Tremec will only fit if you do a Bill E conversion (search for his build under the giant), as the tremec doesn't house a diff....
If you could pull off a build like that then you rock
By the way Jack, I'm home all next week working on the car. PM me if you are interested in coming over.
Bill.
RF GT40
Chassis 061
On the road baby!
Bill Haralambakis is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-wanted-parts-services-needed/19550-5-4l-boss-engines.html
Posted By For Type Date
GT40s.com This thread Refback 10-17-06 01:01 AM
Similar Threads
SBF 302 Track Boss intake wanted YerDugliness GT40 Wanted - Parts or Services Needed 0 04-19-06 02:41 PM
UK crate engines....... Malcolm GT40 Tech - Engines/Induction/Exhaust 6 02-25-04 11:44 AM
New and nearly new engines wbmusarra All GT40 13 06-10-02 12:35 PM
Levy Racing Engines - Driving impressions Roaring Forties All GT40 10 03-21-02 01:30 AM
Unbelievable Boss 429 Mustang All GT40 3 10-05-01 10:53 PM
