Windscreen for a DAX
Ian Anderson
Today an RAC windscreen fitter came to fit my screen
He broke it in the process
Anyone got a spare?
Or a GTD one?
I believe the Tornado will not fit - wrong curvature
ian
Hi Guys
I think The GTD screen should fit, The Dax although 1.5" taller was extended at the bottom edge of the door just above the sill line. The screen and roof area is essentially the same as KVA/GTD.
regards
Chris.
I think you will find that GTD screen should fit as Chris says. Last one i saw had GTD screen fitted.
How anyone can break a windscreen in fitting amazes me. They are a doddle to do. I hope they are refunding you.
Graham @ GTA Racing.
Ian Anderson
Graham
I agree but he said
Glass gets more brittle with age (so what does that say for the 300 year old stained glass bits in churches?)
the screen has been sitting in the spider for years (taped in place)
He checked the fit
Glued up the surfaces
installed the bottom of the screen with a Tornado Rubber
Said something like this is a bit tight and pushed the top drivers side to "fit" it whereupon the top corner cracked - about 3 inches from each side of the corner but will surely be a SVA fail point.
The screen was removed and surround cleaned up.
I swore an awful lot when I heard!
There is some doubt on their liability but I would agree I think they are liable -if they are experts and then break the parts surely they should have known the required clearances.
Just my opinion
