Welding, Essex, UK
I have a mig welder, but not the skill to undertake what I need
Is there anyone (fairly) local who could do me a small welding job? I can bring the items to them. I have two small suspension arms with rose joints. They are cut to size and the rose joint collars are tack welded in place, but as they are a pretty major structural component, I'd like someone with experience to run some weld round for me. I also need a stainless steel weld done (again, very small)
I'm happy to pay for the work.
Anyone interested?
Simon
simonjrwinter at hotmail dot com
Simon:
Wish I was nearby I'd help you in a second.
Just a hint or two if its OK by you.
I would suggest TIG welding those ends in, much stronger and cleaner. Also plan on re-tapping the threads as they will shrink and if you force the rod ends to thread in they have a good chance of galling and may get stuck.
I usually drill a hole thru the tube before installing the bung to get a plug weld in the sides of the bung, just adds a bit of security to the weld.
A bit of anti-seize on the threads on installation will make adjustments later a lot easier.
I would think someone close by would be able to handle those parts for you.
Good luck
Phil
Hi Simon,
Not sure where in Essex you are but I am sure Gary at sidepipes.co.uk would do it for you if you are anywhere near Southend.
