Go Back   GT40s.com > GT40 Market Place > GT40s Wanted, and Parts or Services Needed
GT40s Wanted, and Parts or Services Needed Looking for something, ask here!
Old 8th April 2010, 05:53 AM   #1 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
17 inch wheels and 3.77 or higher R&P
I am stuck at 125 MPH doing open road racing due the to fact Z, Y, W tires are not to be found in 15 inch. Avons are V and thats what I have now so I am in the market for some 6 pin 17 inch wheels for my MK1 which will be just for racing. I also am looking for a 3.77 or 3.07 ring and pinion as I don't like to hear the engine scream for 120 miles. I have a bunch of interesting Ferrari parts, some lambo parts for trade or cash works. If someone has a Good ZF with 3.77 that wants to trade with mine and I will add some cash thats OK too.
Its a shot in the dark but you never know whats on some peoples garage shelves.
SPF GT40 MK1
and a bunch of other stuff
Typing is not my bag
P2164 is offline
Old 8th April 2010, 07:54 AM   #2 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rov
Re: 17 inch wheels and 3.77 or higher R&P
Hi Jack
V rated are good to 150mph
(Actually good for constant 150mph for at least 2 hours)
But I hear what you say about the better diff ratio
DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
IanAnderson is online now
Old 8th April 2010, 08:09 AM   #3 (permalink)
kcoffield's Avatar
kcoffield
GT40: SPF P2174
Big difference between 3.07 and 3.77. Not sure you'll make a big difference by changing wheels/tires but don't know what OD you are starting with. I have 17" Halibrands repros on my car from Vintage Wheel with 315/35/17 Nitto NT01 Skins. I raelly like them and the Nittos are a great tire at a reasonable price (~$215 each).
If someone has a Good ZF with 3.77 that wants to trade with mine and I will add some cash thats OK too. Its a shot in the dark but you never know whats on some peoples garage shelves.
Jack, if memory serves, isn't your box an M1 version of teh ZF? If so, that is a very desireable ZF. Think you may be best served to find the R&P combination that suits. I picked up a low mile 3.77 R&P last year but it's in my box now.
Best,
K
SPF GT40 Mk II, 74 Pantera GTS, 64 Corvette Roadster
kcoffield is offline
Old 8th April 2010, 07:53 PM   #4 (permalink)
P2164's Avatar
P2164
Ian its the rules of the open road race, my tech speed (speed you can not exceed) is 144, but my average speed for the 118 miles should be exactly 125 MPH, then I win.
Kelly your right my ZF is an M1, the only reason I would change the wheels is so I can get tires that are higher speed rated. I plan on keep my Avons and just use 17 inch wheels for racing.
Thanks Guys!
SPF GT40 MK1
P2164 is offline
Old 8th April 2010, 08:18 PM   #5 (permalink)
Ron Earp's Avatar
Administrator
GT40: None.
Hi Jack,
you will be able to find 15" Z rated tires here:
Hoosier DOT Road Race Radials
R6s are what you want and these are what we race on each SCCA weekend. I drive them on the street with my RCR T70. You don't find anything stickier. Just stay out of the rain, although you can spring for Hoosier rains too.
These tires should work for the open road time trial as they are DOT approved. Occasionally though you'll see organizations disallow them specific as they know what an advantage they have over a "normal" performance tire from the various manufactuers.
I run the 275 in the rear and 225s up front for the T70, 225s all around on my Z. Works great. You can get 12-15 heat cycles out of the new R6 compound which is much different from the R6 compound of a few years ago.
Ron Earp is offline
Old 9th April 2010, 11:45 PM   #6 (permalink)
Mike Drew's Avatar
Mike Drew
GT40: None, yet!
Ian its the rules of the open road race, my tech speed (speed you can not exceed) is 144, but my average speed for the 118 miles should be exactly 125 MPH, then I win. :
The rules are that your tire's speed rating has to be higher than your tech speed, right? Your tech speed is 144, your current tire's speed is 150?
What about Dunlop vintage racing tires? After all, that's what the original GT40s run at Le Mans etc. I don't know what their speed rating is though.
http://rogerkrausracing.com/racetire...tage+Tyres.pdf
The only problem with the Hoosiers is that the largest you can get is 275/50, which is pretty short. It would have the effect of lowering your gearing even further.
Mike Drew, Vacaville, CA (
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1....
Mike Drew is offline
Old 10th April 2010, 06:31 AM   #7 (permalink)
P2164's Avatar
P2164
I found my 3.77 from this tread! Next year will be a different at Big Bend for me.
Thanks Ron and Drew for the info on tires. Let me fill in some blanks of Open Road Racing. They are very cautious and that is understandable as Silver State has lost several lives and most due to tire failure.
Last year as a rookie I could not go any faster than 110 mile average with a tech speed of 124, this year I could go up one category and my max speed I can dial in is 125 with a tech speed of 144 max. Next year with the addition of a roll bar I can dial in 150 mph max and must have W rated tires or an approved Z rated tire. If I continue (which I hope so) to the next category its 160 MPH max average and mandatory Y rated tires. The unlimited category I will never race in, its a little to hairy for me and requires far to much modification to my car in terms of roll cage standards.
At least 50% or better of the 160 racers are late model Corvette's right of the show room floor with a couple mods although the unlimited record holder is a corvair powered by a SBC. I really would like to at least get into 155 class in time, with at 3.77 and Y rated tires I can. Worst case is I could borrow Kirby's tires and wheels.
Last year on the return leg (two 59 mile legs) it was hot, almost 100 and the heat coming off the black top was killing me as I was waiting in line to launch, (fastest cars go first) so I got out and walked to the front a couple cars and there was a new corvette with the 650 HP engine in it sitting there idling with the occupants taking a nap with the AC on. That sort of pissed me off. HA!
SPF GT40 MK1
P2164 is offline
Old 10th April 2010, 11:08 PM   #8 (permalink)
kgschrader's Avatar
kgschrader
They're all silver
GT40: SPF MkII
Jack,
They are yours if you need them! No problem at all!!!!
Just tell me.
Kirby
'71 Pantera #1661 - silver/black
'01 Lightning - silver
SPF GT40 Mk II #2155 - titanium/black
'13 Shelby GT500 - silver/black
kgschrader is offline
Similar Threads
17 inch BRM wheels Sean Viney GT40 Tech - Chassis,Brakes,Tires,&Wheels 6 21st May 2009 03:49 PM
New 17 inch wheels from Vintage Bob Lacey Vendor and Manufacturer Announcements 5 20th February 2007 10:02 PM
Vintage Wheels 17 inch BRM delay Bob Lacey RCR Forum - RCR40 /SLC / P4 / MKIV 53 9th November 2006 05:16 PM
15 or 16 inch wheels Henrik_Smedberg GT40 Tech - Chassis,Brakes,Tires,&Wheels 14 19th January 2005 04:40 PM
Pics of GT-40s w/ 17 inch wheels Brian McCarthy GT40 Tech - Chassis,Brakes,Tires,&Wheels 14 16th February 2003 12:19 AM
