Looking for an speedo gear reduction unit ERA GT 40
Hi to all,
I miss the speedo gear reduction unit and the short cable from a ERA GT40.
This is mounted on 2 ft from the Transaxle , between the long and short speedo cable
this is the problem I found out from the default from the failed SW speedo meter
thanks for any reply and help.
Simon
Julian
Simon,
It sounds like your ERA has a speedo correction adapter gear. I can check the weekend what I have on mine if it is a stanadard ERA part. If you know what speedo you have with the revs/mile and which angle adapter you have on the ZF (1:1 or 1.1:1), then you should be able to calculate the inline gear adaptor you need. Most good Speedo shops should be able to supply one.
Did you talk directly with ERA?
A lot of folks are going with GPS speedos, I'm not sure if that would be a legal option in the Netherlands?
Julian
Hi Julian,
I have already contact ERA ,but not yet an answer.
I miss also the short cable and I think I need no angle reducer.
Looking forward how the speedo on your ERA works , mine has SW gauges
Simon
