Go Back   GT40s.com > Sports/GT Racers, Can Am, Lola, Porsche,& Modern Racing > Lola T70 Lounge
Lola T70 Lounge Spider and coupe talk, replicas and real.
Old 03-08-08, 07:26 AM   #1 (permalink)
markpreece's Avatar
Gold Supporter
GT40: UK
Rep Power: 3 markpreece is on a distinguished road
Rear suspension advice
Hi I am rebuilding my T70 replica replacing the gearbox/rear suspension. This means re-designing the lower rear suspension it is currently reverse a arm with a trailing arm. I have changed the rear uprights to alloy Ultima uprights which means i can no longer mount the trailing arm to the upright (see original setup picture) as it will obstruct the rear wheels.
I was thinking of adding a brace to the a-arm and mounting the trailing arm to the side of the a-arm the mounting points to the chassis would remain the same(see proposed setup picture) but a friend of mine who rebuilds race cars did not like the idea.
The pictures are not accurate they are just to outline the origial/proposed setup.
I know there is a wealth of knowledge and experience on the forum and would value your feedback. Thanks in advance Mark
markpreece is offline
Old 03-08-08, 03:37 PM   #2 (permalink)
Russ Noble's Avatar
Russ Noble
GT40: Building scratc
Re: Rear suspension advice
Hi Mark,
Apart from introducing side loads into the RJ's on the upright, I can't see any downsides to this. You may have to replace the RJ's more frequently due to increased loads and wear. The RJ's here are probably 1/2 " so should be able to take the extra loads OK IMHO.
The other option would be to space the wheels out. Just a matter of what's easiest.
Cheers,
Russ
Russ Noble is offline
Old 03-08-08, 04:32 PM   #3 (permalink)
grp2viva's Avatar
grp2viva
Rep Power: 2 grp2viva will become famous soon enough
Hi Mark
I don't see any probs with that at all. Just makes it exactly the same as a real T70 Spider, and there's no problems with them....
Good Luck
Darren
CRC Racecar Engineering
grp2viva is offline
Old 03-08-08, 09:01 PM   #4 (permalink)
Phil's Avatar
Phil
3 Tenths
GT40: scratch built Mk1
Hey Mark
I would second what Russ and Darren said...just make sure that your thru-bolt in the bottom of the upright is grade 8, or the metric equivalent.
Phil
Scratch Built Spaceframe, 289, Pin Drives
Phil is offline
Old 03-09-08, 07:36 AM   #5 (permalink)
markpreece's Avatar
Gold Supporter
GT40: UK
Russ thanks for the feedback would struggle to space the wheels. Darren i have a cut away of the first T70 spider the arm seems to go to the upright but it is difficult to tell, had to pull out my tamiya 3B kit at 1 in the morning and you are spot on thanks. Phil thanks for the comments. I have attached an image of some rear "measuring up" I will get a full build site underway soon to show the rebuild.
(sorry can't upload images at the moment will try and add picture later!!!)
Old 03-16-08, 02:36 PM   #6 (permalink)
Dogface's Avatar
Dogface
GT40: RF 115
Rep Power: 1 Dogface is on a distinguished road
Pictures
I will be picking up my Lola Spyder replica in 2 weeks. Can you please post more pictures of your Lola so I can get more ideas on how to finish my car.
Berst regards
John
Dogface is offline
