Old 04-11-07, 03:38 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
more_ghz_project's Avatar
more_ghz_project
Romania
GT40: i wish....
Rep Power: 3 more_ghz_project is on a distinguished road
Workin on a '68 Jaguar XKE
A friend of mine is working on one and has a hard time getting the starter off
the starter is stuck, and the solenoid just clicks :|
do you have any ideas ?
more_ghz_project is offline
Old 04-11-07, 08:14 AM   #2 (permalink)
Dalton
4 Tenths
Rep Power: 8 Dalton is just really nice
Re: Workin on a '68 Jaguar XKE
I drove a '68 roadster daily for years and loved it, and never had a starter problem, so can't help much from experience. I sold the workshop manual, but it would just have said, in passing, "unbolt and remove starter", or something helpful like that. I suggest you try the nearest Jaguar Club.
Dalton
Dalton is online now
Old 04-11-07, 10:19 AM   #3 (permalink)
MN12
GT40: saving for RCR
Rep Power: 8 MN12 is on a distinguished road
Thankfully I have never had to replace the starter on mine but the 4.2 should be pretty straight forward. There is a good online forum here
JagFORUM - the world's No 1 online club for Jaguar enthusiasts
These folks sell a good gear reduction starter for the E
Classic Jaguar : Jaguar High Performance Parts and Restoration
MN12 is offline
Old 04-11-07, 10:33 AM   #4 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on the Thames: Marlow, Bucks
Rep Power: 35 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
WD40, Plus Gas, or SAS with gentle heating and cooling and more of the above lubricant. And some patience using good spanners. Sometimes a 'so very tiny' turn clockwise can do the trick as well.
David Morton is offline
Old 04-11-07, 11:14 AM   #5 (permalink)
toy264's Avatar
toy264
Rep Power: 5 toy264 will become famous soon enough
If it's similar to the '67, there's a 1/4" ring on the stsrter face that aligns the stsrter with the block. Sounds like yours is binding there or it would just drop free when the bolts were removed. Be careful if you heat it with a torch as there's usually grease/oil nearby. Don't ask.
toy264 is offline
Old 04-11-07, 01:04 PM   #6 (permalink)
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Rep Power: 9 wolodymyr is on a distinguished road
If its a Manual box, stuck starters can sometimes be freed by putting the car in gear and rocking the car backwards and forwards.
DAX 302 Installing Alloy Rad
wolodymyr is offline
Old 04-11-07, 03:14 PM   #7 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Getting the starter off is not so much of a problem, it's getting it back on again! I remember in the mid 70's having to do one for a customer. Four hours to remove it and eight hours to put it back on again! I've no idea what the factory book time is. From what I remember access is severely restricted even after removing a lot of surrounding paraphernalia.
Good Luck!
Russ
Russ Noble is online now
Old 04-11-07, 03:41 PM   #8 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
Wink Re: Workin on a '68 Jaguar XKE
'Glenns' Foreign car manual gives a flat rate of 2.7 hrs for Removal- Overhaul-Refit of Starter. You must have been slackin Russ!
Instructions, are fairly basic- Disconnect battery-remove starter lead- remove attach bolts. Sounds like they wrote the book but never worked on the car.
Jac Mac
jac mac is offline
Old 04-11-07, 05:33 PM   #9 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
Ah! Well then, racas mates best bet would be to get a firm quote from someone based on the Glenn flat rate and let them do it for that!
Russ
Old 04-12-07, 05:42 PM   #10 (permalink)
more_ghz_project
Romania
GT40: i wish....
thanks for the help guys !
the guy managed to get the darn thing off, i belive it was a Lucas model
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/paddock/21434-workin-68-jaguar-xke.html
Posted By For Type Date
"Workin on a '68 Jaguar XKE" - thread profile :: BoardReader This thread Refback 04-06-08 06:55 AM
GT40s.com This thread Refback 04-11-07 09:05 AM
