Old 06-27-07, 07:00 PM   #1 (permalink)
p thompson's Avatar
p thompson
Administrator
GT40: None
Interesting Aircraft..
Hi all -
I received an email today detailing an interesting aircraft.
The details are as follows:
The new RP-4 aircraft shown here, is being built to attack the World 3, 15 and 100 Kilometer Speed Records.
Engines: Two high performance V-8 engines power the RP-4, representing the best compromise among size, weight, power and availability. Tandem mounted, each engine drives its own propeller. The front engine drives the front prop directly and the rear engine, through gearboxes which bypass the front engine, drives the rear prop in contra rotation.
Independent fuel and cooling systems allow for single engine operation.
Propellers: Utilizing NASA Unducted Fan Technology, two four-blade propellers with variable pitch hubs were constructed. The blades consist of 84 layers of prepreg carbon fiber and are 58 inches in diameter.
Cooling: During engine warm up, thermostats cycle engine water through the oil sump heat exchanger to quickly bring engine oil to operating temperature. Once up to temperature, the thermostats then direct engine water to a series of aluminum tubes within the wing. These tubes are immersed in 50 gallons of water which carry engine heat to the wing surfaces which are cooled by the slipstream. Separate series of tubes are provided for each engine enabling autonomous cooling of either engine. Wing water can be diverted through an auxiliary radiator located in the tail cone for cooling on the ground if needed. The forced induction systems generate high inlet temperatures and induction air is directed through evaporators charged by air conditioning compressors. This system also provides conditioned air to the cockpit.
Fuel: A 100 gallon fuel cell below the wing supplies fuel to engine-driven pumps which feed the injectors.
Gear: All gear retract aft into the fuselage. The main gear articulates as it retracts holding the wheels parallel to the fuselage throughout retraction.
Wing: The RP-4 wing is one of the most complex ever constructed. Less than 3 inches at its thickest point, it nevertheless contains flaps and ailerons as well as 200 feet of tubing and nearly 400 fabricated fittings and connectors which comprise the cooling systems.
Fuselage: Built entirely of large diameter chrome moly tubing, the fuselage is skinned in 60 thousandths aluminum and is 31 inches in diameter.
Empennage: The vertical and horizontal stabilizers are, like the wing, both riveted and bonded together. The vertical stabilizer houses the nav/comm antennas as well as pitot and cockpit ventilation systems.
Performance: The RP-4 is designed to be a high performance aircraft. (really?)
Eric Hereth, master machinist, fabricator and welder, built all components of this remarkable aircraft from scratch, with the exceptions of engine long blocks, wheels, and hydraulic components.
Jerry Baer assisted in all phases of construction.
An interesting concept indeed....!
A few pics
ID:	21449   Click image for larger version
ID:	21450   Click image for larger version
regards
Paul Thompson
p thompson is offline
Old 06-27-07, 11:34 PM   #2 (permalink)
Conquest351's Avatar
Conquest351
5 Tenths
GT40: None Yet
Rep Power: 7 Conquest351 is just really nice
Re: Interesting Aircraft..
Looks like a supercharged 2,000hp garbage disposal unit!!!
Conquest351 is offline
Old 06-28-07, 05:47 AM   #3 (permalink)
John Lowe's Avatar
John Lowe
GT40: RCR MK1
Rep Power: 5 John Lowe is a glorious beacon of light
Gosh, what a machine, love the contra prop, didn't know that you could still get meccanno
John
John Lowe is offline
Old 06-28-07, 03:05 PM   #4 (permalink)
OhioMark
Rep Power: 3 OhioMark is on a distinguished road
I can't imagine those wings providing much lift. Then again, I'm not an
aero. engineer so what do I know. Cool photo's! Thanks!
Mark
OhioMark is offline
Old 06-28-07, 05:58 PM   #5 (permalink)
SpyderMike's Avatar
5 Tenths
GT40: So Cal
looks like a modern day Bee Gee racer
SpyderMike is offline
Old 06-28-07, 06:54 PM   #6 (permalink)
Scott Calabro's Avatar
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Rep Power: 12 Scott Calabro is a splendid one to behold
Talk about flying on the prop !
Two BBC's .... way cool.
They could be the Venerable ORENDA V8's.
I wonder what it crosses the fence at !!!
S
TORNADO SPORTS CARS USA
WWW.TORNADOSPORTSCARS.COM
413-977-4408
Scott Calabro is offline
Old 06-28-07, 07:10 PM   #7 (permalink)
Ron Earp's Avatar
Retiree
Those props don't look like real load bearings props to me. I don't think I'd climb in that thing, nope, don't think I would.
R
Ron Earp is offline
Old 06-28-07, 10:19 PM   #8 (permalink)
2124's Avatar
2124
5 Tenths
GT40: Rescue, CA
Rep Power: 10 2124 is a glorious beacon of light
I guess I am more sure then that.
I KNOW I wouldn't.
CAV #80, 331 Keith Craft, RBT Swift DB5
2124 is offline
Old 06-28-07, 10:24 PM   #9 (permalink)
Ron Earp's Avatar
Retiree
I wonder how the cg works out? I'm reminded of a see saw with that gear in the middle. I bet on landing flair near stall it could be interesting. I'd be scairt.
Ron Earp is offline
Old 06-29-07, 02:15 AM   #10 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Rep Power: 37 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
I think it is really quite sexy and very cutting edge. It would merit some more investigation before I would say wether I would fly it or not. One point of interest is the horizontal stab being lower than the mainplane.
Cooling matrixes in the wings/fuel tanks are nothing new - its how we cooled the radar transmitter on the Mk111 AEW Nimrod.
On balance, with safety issues addressed, yes I'd go for it.
David Morton is offline
Old 06-29-07, 03:57 PM   #11 (permalink)
BenL's Avatar
BenL
6 Tenths
The description of the props is "Propellers: Utilizing NASA Unducted Fan Technology, two four-blade propellers with variable pitch hubs were constructed. The blades consist of 84 layers of prepreg carbon fiber and are 58 inches in diameter."
I suspect those are temporary, sheet metal propellers.
BenL is offline
Old 06-29-07, 03:58 PM   #12 (permalink)
Brian Magee's Avatar
Brian Magee
GT40: GTD
Rep Power: 12 Brian Magee is on a distinguished road
Dave
Would you fancy flying this?
http://www.crazyaviation.com/movies/CA_SU-30.wmv
Brian.
GTD, 289, ZF.
Brian Magee is offline
Old 06-30-07, 11:22 AM   #13 (permalink)
David Morton
Brian,
What red blooded man wouldn't ? That is just so 'cutting edge' aero, it's positively orgasmic.
Old 06-30-07, 11:41 AM   #14 (permalink)
Ron Earp's Avatar
Retiree
That I'd like to give a go. But heck, I'd like to give about anything a go that will manage more than a measly 1200 ft/min climb and 130 kts!
Ron Earp is offline
Old 06-30-07, 12:18 PM   #15 (permalink)
JIMMYMAC
Rep Power: 17 JIMMYMAC has much to be proud ofJIMMYMAC has much to be proud of
I thought it reminded me of something I saw in Japan
Cordially,
James
Graviner Fire Suppression
JIMMYMAC is offline
Old 06-30-07, 12:21 PM   #16 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
I'm only 44 and have 2 young daughters.
I'll stay out of IVAN'S creations thank you.
Looks like a blast though.
Call me old fashioned, I'd rather ride aft seat in a P51.
Glad to hear your back David .
Cheers,
Scott
413-977-4408
Old 06-30-07, 12:38 PM   #17 (permalink)
David Morton
Thanks Scott. Believe me, nice to be back.
Su. Tu, and Mi made some wonderful machines as well as some diabolical ones - but then didn't we as well.
If it looks right, go and give it one.
but - of all I flew I liked the DHC6 Twin Otter because of it's extreme abilities on all sorts of terrain with the most incredible STOL performance.
Old 06-30-07, 01:19 PM   #18 (permalink)
Malcolm's Avatar
Malcolm
Gold Supporter
GT40: GTD
At the last Farnborough Airshow I saw one of those planes do the double backward sommersault. Just awesome. Previously also seen the tail walking antics. Both just so cool. Those pilots do know what they are doing but I guess I would empty my stomach by the end of the first turn!
Malcolm
GTD40, Mazda MAX5 MX5, Porsche 996 C4S
Lotus 51c for sale
Malcolm is offline
Old 06-30-07, 07:50 PM   #19 (permalink)
Pete's Avatar
Pete
GT40: GT40 Australia.
Rep Power: 41 Pete has a brilliant future
