Hi,
I am hoping someone may be able to help I recently imported into the UK a complete hydraulic car lift with UK power supply this came with a 3 pin unfused US plug..
I was advised by the company that supplied the lift that the wiring was as follows,
USA UK
Black Live
White Neutral
Green Earth
and that I would need to fuse it at 30 amps. I put some 30amp fuse wire in place of a fuse as our plugs go to 13 amp only and switched it on. It worked for a short time and then, once the smoke had cleared I discovered the main 30 amp fuse in the distribution box had blown and a section of wiring had burnt out.
I bought a USA adaptor plug and traced the wiring which seems to indicate that white is in fact the live, not black (can anyone confirm this). I rewired the plug, and the unit is working but blowing 13 amp fuses. I am reluctant to try fusing the plug at 30 amps again but don’t know any other way of getting it to work.
I was thinking of buying a small generator to power it but this would be a slightly expensive solution. I have tried finding out information from the supplier to see what current the unit may draw but have received no answer. Is it normal for USA plugs to be unfused and plugs able to cope with 30amps does anyone have any ideas on how to over come this problem?
Nick
USA UK
Black Live
White Neutral
Green Earth
Nick
