P&W C 308C 600 hr insp.
Thought some of you guy's may want to see a Pratt & Whitney corporate turbofan with the engine cowlings opened for a 600/1200/ 12 mo. inspection.
R&R eng oil
R&R eng oil filter
Remove and inspect eng oil chip plug
R&R fuel filter
Inspect 5 & 7 o'clock initer plugs and ops check
External visual
Ground run, leack check and re-service oil reservoir.
Oh, and the logbook sign off!
S
Dimi Terleckyj
Thanks Scott
I think with a little cut and shut I should be able to squeeze one of these into my 40.
The only thing I might not be able to work out easily is the ECU to control it.
Impossibilities I do now.
Miracles take me a bit longer.
Dimi.
