Old Car:
1. Adjust valves for fuel system and operate pump handle to pressurize fuel tank.
2. "Tickle" the Solex carburetors until fuel begins to leak out.
3. Move timing lever for the magneto to the start position (all the way up).
4. Have one person put their hands over both carb intakes to manual choke the engine.
5. Other person turns over the engine with crank handle.
6. Once the engine catches, quickly remove your hands from the carbs.
7. Move lever for the magneto timing down a couple of notches.
8. Lower bonnet and fasten straps to secure it.
9. Passenger should keep eye on fuel pressure gauge and operate pump handle as needed.
Modern Car:
1. Insert and Turn key
For daily driving, starting a modern car is much simpler, but there's no charm in it.
Modern Car:
