Have a garage wiring question here my worn-out brain just can't figure out....
Here's the background. I'd like to add more lighting in my garage (who doesn't want more light in their garage??). There's an existing circuit with a single overhead light with the switch (single pole) on the end of the run - see diagram, everything inside of the red dashes. I'd like to add another circuit with another overhead light (maybe two) off this existing circuit, separately switched in a new double gang switch box in place of the existing single, preferably with the switch at the end of the new run.
Will the wiring configuration in my hand-made diagram work? Hot wire is black, white/neutral is the light green, ground not shown (but will be included obviously).
Any help is mucho appreciato.
