Not sure if this is the correct place to post, but I'd just like to post my appreciation for Frank Catt's help today.
My GTD project has the old style rubber bushes in the suspension, which I needed removed. I'd heard that Frank had a jig and press to remove these, so called him up and went down today to get them pressed out.
When I got there, we discovered the bushes had a steel sleeve which meant that Frank had to turn up on the lathe a piece of steel to use especially to press my bushes out. This he did on the spot, and wasted no time in sorting the bushes for me.
When I spoke to him the other day about my gearbox mounting issues (see other post), he also told me he had templates for custom made mounts, and I picked up a set of mounts today which fit perfectly.
Again a BIG thank you to Frank, he IS the man!
Simon
Simon
