GT40s.com (http://www.gt40s.com/forum/)
-   The SLC Clubhouse (http://www.gt40s.com/forum/slc-clubhouse/)
-   -   Mounting front clip (http://www.gt40s.com/forum/slc-clubhouse/51415-mounting-front-clip.html)
dazzle 19th December 2017 12:53 AM
Mounting front clip
Anybody else have to remove the front wheels to get the front clip on or off?
Am I doing something wrong?
I have 19 inch Forgestar F14s.
Aaron Hamilton 19th December 2017 08:02 AM
Re: Mounting front clip
It’s a custom build. Sometimes you’ll need to modify parts. It’s easy since it’s fibetglass. Cut and paste..
sswartz 19th December 2017 11:00 AM
Colin,
I have 19" CF5V's withNitto Invo 275/30 ZR19 (will be upgrade dto Michelin Pilot Sports after build/shakeout). I don't have any issue taking the nose off/on. I do have an interference issue with diffuser at full droop which I hope can be resolved with a little trimming of the diffuser.
CamT 20th December 2017 12:21 AM
Colin - do you have a side shot of your front clip mounted to the car, with the wheels sitting at ride height? Curious what your clearances are like between the tires and wheel well. I'm assuming it's contacting at the lower edge of the wheel well?
dazzle 20th December 2017 12:57 AM
Cam, yep the lower part of the wheel well.
It'll be a few days before I get the car back down onto the ground. I will take some photos then.
CamT 20th December 2017 01:24 AM
I have measurements and photos in post #14 if you want to compare against your car. I was able to install and remove the clip fine without having to remove the wheels.
14. It’s all about the stance – Cam's Superlite SLC
Frank833 3rd January 2018 05:51 PM
No
ditto
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO v2.0.38 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
