GT40s.com (http://www.gt40s.com/forum/)
-   Superformance GT40s (http://www.gt40s.com/forum/superformance-gt40s/)
-   -   Ignition Switch? (http://www.gt40s.com/forum/superformance-gt40s/51464-ignition-switch.html)
MHNCO 1st January 2018 12:39 PM
Ignition Switch?
I am in the process of completing a new center console that includes a rocker switch for the front lift. I have been considering whether to replace the keyed ignition switch with a toggle or rocker switch. Thoughts? I suppose if one was concerned with security they could added a hidden switch in the back if they were worried someone would jump in and drive away. I never leave my car in a spot where I would worry about taking the key with me and think if someone wanted to steal the car, a keyed switch is not going to stop them.
Does anyone know the amount of current that runs through the SPF ignition switch? Thanks
Big-Foot 1st January 2018 02:31 PM
Re: Ignition Switch?
Many years ago I setup 6 toggle switches in series on a small panel. I oriented the toggles so they represented a binary code. If all 6 toggle switches were oriented with ON being to the left, you would simply flip all toggles to the left - you could start the car with the starter button. I had them mixed up of course so it was something like 010011.
MHNCO 1st January 2018 02:40 PM
Now that is a clever approach Randy! What does that give you... 64 possible combinations? I think one along with the battery cutoff and a hidden switch in the back would provide as much security as one might need but I admire your ingenuity!
Mark IV 1st January 2018 02:59 PM
Mike,
The ignition switch has a "main" power terminal that all of the accessories get power from that is "hot' al of the time, but the ignition and running modes don't take a great deal of amperage. Blas can walk you through how to power the vehicle and separate the ignition. We have done a car as original by moving the key switch to the "start button" location on the dash. That would allow you to remove the tunnel to instrument panel portion of the console so it is open as per the FAV cars.
jac mac 1st January 2018 02:59 PM
Bought an old Triumph 2500S a while back, previous owner had fitted a battery cut off to back of cigarette lighter which he had gutted and fitted an adaptor to operate cutoff. Had to push n turn lighter to operate.
Big-Foot 1st January 2018 03:09 PM
Thanks Mike.
I should have added that the correct sequence would engage a relay for the ignition box.
I’ve also heard of the trick that Jac mentions and find that pretty clever..
MHNCO 1st January 2018 03:32 PM
Originally Posted by Mark IV (Post 516989)
Mike,
Thanks, I was looking over the diagram I bought from Blas. I don't think mine is hot to accessories all the time but I need to get in there with a meter and check. I think the fuel pump is powered by that circuit as well as the dash and heater fan etc. As long as the cooling fans don't draw through that circuit I would assume a 20amp rocker would be sufficient. While I understand binary and Randy's approach I am not an electrician so if I'm off in left field hopefully someone will enlighten me. Thanks!
To your point Randy, maybe a better solution is a relay triggered by a rocker switch.
Walt Williams 1st January 2018 09:18 PM
Mike,
I cut down my key and epoxied a black knob on it that looks like the other knobs/buttons on the dash. You can't even tell it is a ignition switch.
Dave Hood 1st January 2018 10:18 PM
I kept the key ignition but had Paul Whitlock relocate it to the dash. I put a dual USB power hub where the ignition switch was. The USB hub also has a digital voltmeter built into it.
Amazon.com: LiDiVi 2 USB Charger Socket Power Outlet 2.1A & 2.1A with 12-24V Voltmeter Green LED Digital Display for Car Boat Marine Mobile: Electronics
Mike Drew 5th January 2018 12:12 AM
A friend hid a starter interlock in plain sight. He routed the ‘start’ wire through an unmarked toggle switch, one of many on the dash. In practice, the switch needs to be flipped on in order for current to flow from the ignition switch to the solenoid and engage the starter. Once the car is running the toggle is flipped off. It will run forever but when you shut it off, it won’t restart until you flip the toggle again.
Brilliant.
Would work great against carjackers. Gun to the face? Shut the car off, leave the keys in the ignition, get out and run away. Perp gets in, turns the key, the car lights up but starter doesn’t work.....
IanAnderson 5th January 2018 02:43 AM
Mount one of these behind a panel
Then turn it on with a magnet
MP201901 | Cherry Rectangular Magnetic Proximity Sensor Inductive Proximity Sensor, 28.58 x 19.1 x 6.35 mm | Cherry
Oh they used these in South Africa and locked the brakes with a solenoid. Unless you knew where the switch was located you could not move the car
MHNCO 5th January 2018 02:54 AM
That’s kind of a neat idea Ian. Actually, these are all neat ideas thanks! Yes
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO v2.0.38 (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
