Old 12-17-06, 10:09 AM   #1 (permalink)
JayPSC's Avatar
JayPSC
Deceased 5-24-07, RIP
GT40: RCR
Rep Power: 7 JayPSC is on a distinguished road
Fixing brake lines to pass SVA in UK
I notice that the brake/clutch lines need to be fastened every 300mm to pass the SVA in the UK, any ideas how to fasten the sections running through the central tunnel?
Corrado G60 (For Sale)
Drift Volvo 760 Turbo
Z32 300ZX Twin Turbo
RCR40 in progress
JayPSC is offline
Old 12-17-06, 10:18 AM   #2 (permalink)
Ron Earp's Avatar
Site Administrator
Re: Fixing brake lines to pass SVA in UK
How is the inspector going to determine that they are fastened every 300mm?
You could use P clips and glue them on the lines every 300mm in the proper orientation. Then, you could drill holes every 300 mm. And, probably with a lot of cussing you could manouver the lines and P clips to correspond with the hole and get a pop rivet through it from outside the tunnel. Use of slightly oversized holes would help here I'd imagine.
Ron Earp is offline
Old 12-18-06, 05:08 PM   #3 (permalink)
JayPSC's Avatar
JayPSC
GT40: RCR
Yeah I feared that'd be the case, was hoping for a method that'd involve less swearing
RCR40 in progress
JayPSC is offline
Old 12-18-06, 05:56 PM   #4 (permalink)
Ron Earp's Avatar
Site Administrator
Well, every 300 mm on the tunnel you could cut a 1" diameter hole with a hole saw. Then, you could fabricate 2" circles from aluminum to cover them up, and, to give you an easy way to have an access panel for the afixing.
You could either rivet the line to the panel, then rivet the panel to the tunnel, or, rivet the line to the tunnel right next to the cutout and use the cutout to help get it riveted.
Ron Earp is offline
Old 12-18-06, 06:10 PM   #5 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
Fasten your lines to a strip of alloy unequal angle (approx 10mm x 30mm x 1.5mm) that is slightly longer than the tunnel. Bend the angle over at each end and fasten to the tunnel/tub ends, take a couple of before/after pics to show the inspector. This way if you ever have to work in that area you just remove the whole assy from the car. Just to be sure run the idea past your inspector before you do it.
Jac Mac
jac mac is offline
Old 12-18-06, 06:36 PM   #6 (permalink)
Ron Earp's Avatar
Site Administrator
JacMacs idea sounds like a lot better solution to me!!!
Ron
Ron Earp is offline
Old 12-18-06, 11:45 PM   #7 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Rep Power: 20 delaneyp is a splendid one to behold
I guess it all comes down to the SVA definition of "fastened". Mine are zip-tied to the insulated a/c pipes running thru the tunnel - every 300mm as per the book, & this was ok.
At worst, you could run the pipes at floor level & use P-clips pop-riveted to the floor under the main rad pipes (& take lots of pics) !
Good Luck,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 12-19-06, 04:24 AM   #8 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
GT40: Albany west Aus
Rep Power: 6 albanygt40 is a jewel in the rough
Could you try and use these sort of clips.
I used them all over my car to secure the brake pipes.
What! another DRB GT40...
albanygt40 is offline
Old 12-19-06, 04:45 AM   #9 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17 IanAnderson is a jewel in the rough
Jay
Mine run down the side next to the gearchange.
They did not want to see that they were fixed every 12 inches except in the "open areas"
And we ran the lines in this type of clip
https://secure.visav.co.uk/avshop/pr...at=29&scat=128
Doubles can be a pain to locate but I think I may still have a contact number somewhere from Jaguar spares.
IanAnderson is online now
Old 12-19-06, 09:11 AM   #10 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
I like JacMac's idea as well. I might suggest a strip of 1/16" thick, self stick closed cell foam on back of the strip to prevent vibration noise in midtunnel.
Lynn
Sabre GT40/5L EFI/G50/50
Always verify parts or products discussed for your own use.
llarsen is offline
Old 12-19-06, 07:20 PM   #11 (permalink)
jac mac's Avatar
jac mac
New Zealand
Thumbs up Re: Fixing brake lines to pass SVA in UK
Lynn
Or a couple of strips of velcro glued to chassis & angle alloy.
Jac Mac
jac mac is offline
Similar Threads
parking brake system linder GT40 Tech - Chassis,Brakes,Tires,&Wheels 7 02-09-04 01:13 PM
WHERE CAN I FIND BRAIDED STEEL BRAKE LINES? chip GT40 Tech - Chassis,Brakes,Tires,&Wheels 5 05-13-02 07:49 PM
