Old 01-25-07, 12:19 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Bill D
I Have No Life
Rep Power: 32 Bill D has much to be proud ofBill D has much to be proud of
Rear Bulkhead Window
Does it attach on the cockpit side or the engine side?
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-25-07, 12:26 AM   #2 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
Re: Rear Bulkhead Window
I mounted mine from the engine side.My inner roof structure ws already finished when I got my window and I didn't want to cut into it .
RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889
Pantera1889 is offline
Old 01-25-07, 11:09 AM   #3 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 37 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Dean,
this is your car as of this morning..
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 01-25-07, 11:12 AM   #4 (permalink)
Bill D
I Have No Life
I mounted mine the same way, but it's causing major fitment problems with the roll bar and spider. As mounted, it hits the roll bar. This in turn pushes the rear bulkhead forward, causing the spider to move forward.
Looks like I may have to change it to the inside this weekend to see if that corrects the problem.
Thanks for replying.
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-25-07, 11:15 AM   #5 (permalink)
Bill D
I Have No Life
Thanks Fran. That actually will make it easier to install the upholstery.
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-25-07, 11:20 AM   #6 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
Any chance one of you have a picture of what you are talking about? I am trying to pay close attention to your build threads as I will be walking down the same road shortly.
Dlampe is offline
Old 01-25-07, 11:45 AM   #7 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Gents.
it was designed to go on the cockpit side and create a pinch for the carpet on the firewall and then give you a nice finished trim around the window...I know some of you are not using carpet....so its your call in that case.
Make sure to use the correct length nyloc nuts and ss bolts/cap heads , if the shank is too long it will hit the rollbar and create a fitment issue...
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
Old 01-25-07, 11:56 AM   #8 (permalink)
Bill D
I Have No Life
Dean-
In this picture, the bulkhead window is attached on teh back of the bulkhead. Fran says it should be on this (cockpit) side.
This isn't the best picture of what I'm describing, but if you look closely at the rear bulkhead, you'll see the window and frame attached. The roll bar then pushes against the bulkhead, forcing it forward and moving the spider forward out of alignment.
That explains my fitment issue.
Sir Fran
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-25-07, 01:17 PM   #9 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
Thanks Bill.
Fran, you are one step ahead of me once again. It is looking very good. Did you get my note about the headlight bucket install?
Dlampe is offline
Old 01-25-07, 01:33 PM   #10 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Yep....sure did....pussy
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/rcr-forum-rcr40-rcr70-p4-mkiv/20590-rear-bulkhead-window.html
Posted By For Type Date
GT40s.com This thread Refback 01-25-07 11:20 AM
GT40s.com This thread Refback 01-25-07 08:56 AM
