Factory powdercoated chassis
| RCR Forum - RCR40 / RCR70 / P4 / MKIV Sponsored by Race Car Replicas. |
| | LinkBack (2) | Thread Tools | Display Modes |
| | #21 (permalink) | |
| mj_duell Rookie ![]() Join Date: Nov 2004 Location: Rochester, New GT40: TTR/GT
| Re: Factory powdercoated chassis Quote:
--Mike / Turn Ten Racing, Inc.
__________________ <TABLE><TR><TD rowspan=4 valign=top> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. </TD><TD> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. </TD></TR><TR><TD> U.S. Sales: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. / (585)223-5917 </TD></TR> <TR><TD> Canadian Sales (D&D Cobra/GT Technology): To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. / (450)658-2315</TD></TR> </TABLE> Last edited by llarsen; 04-06-07 at 03:50 PM. Reason: images removed because of bad form - Lynn | |
| | #22 (permalink) | |
| Big-Foot Moderator ![]() Join Date: Jan 2007 Location: Minneapolis, MN GT40: RCR40 - #45
![]() That would look awesome.. I'm also thinking of doing the same and making the carpeting snap in/out.. My car will be the car that the customers will look at and drive before they place their orders.
__________________ Regards - Randy GT40 RCR40 #45 G50-331-Weber IDAs My build site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | |
| | #23 (permalink) |
| albanygt40 5 Tenths ![]() Join Date: Nov 2005 Location: Albany West Aus GT40: Albany west Aus
| Re: Factory powdercoated chassis No, no one of you Guys have to polish one. If I had a RCR first job would be to get the buff out and reap that lovely shine. Fran should offer a polished chassis as an option. Oh and freight to Australia should be free.
__________________ DRB GT40 #103 |
| | #25 (permalink) |
| ahirsbrunner Administrator ![]() Join Date: Feb 2005 Location: Chicago, IL USA GT40: RCR-40 #24
| Re: Factory powdercoated chassis FYI, this is the finish being referred to (by Paolo): Alsa Corp | ChromeFX: Product Information-Our Chrome FX can produce a real METALLIC FINISH on any surface Al |
| | #27 (permalink) |
| gt40fran Sponsoring Vendor ![]() Join Date: Sep 2001 Location: Manufacturer of GT40: Michigan,USA
| Re: Factory powdercoated chassis You could be the first...
__________________ FRAN HALL replica manufacturer..... RCR-40..Mk1, 2 and Mk4 RCR-70 Mk3b RCR-70 Spider RCR-P4 Superlite Coupe Superlite Roadster...including Electrolite RCR917 XJ13 for SCF To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
| | #28 (permalink) |
| Re: Factory powdercoated chassis Blue black....very cool colour...
| | #29 (permalink) |
| MReid 4 Tenths ![]() Join Date: Apr 2007 Location: Connecticut GT40: RCR Mk1
| Re: Factory powdercoated chassis Now I'm really drooling! I hear the clock ticking...I can almost hear the phone ringing...any day now...looks fantastic, Fran!
__________________ [COLOR=black]Have fun with your build! - Mark[/COLOR] [COLOR=blue][/COLOR] [COLOR=blue][I]FFR Daytona Coupe[/I][/COLOR] [COLOR=blue][I]RCR Gt40[/I] [/COLOR][COLOR=blue][I]Mk1[/I][I] in the garage, and underway![/I][/COLOR] |
| | #31 (permalink) |
| Re: Factory powdercoated chassis YES.....
| | #32 (permalink) |
| Dimi Lifetime Premier Supporter ![]() Join Date: May 2006 Location: Seaforth,Sydney GT40: DRB Chassis 68
| Re: Factory powdercoated chassis Hi All I must admit I like the look of powdercoated finishes but the one major draw back is that it is OK as long as no holes have to be drilled after the coating has been done or that the finish does not get scratched right through. Once the surface integrity has been damaged and corrosion gets in it creeps under the surface and after some time the powder coating flakes off in sheets. Also very difficult to refinish if needed. Dimi
__________________ To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
| | #33 (permalink) |
| Re: Factory powdercoated chassis Thats why we pre-drill the chassis prior to coating on all the exterior surfaces...it is a lot of extra work for us to powdercoat a chassis but its less than if a customer decided to do it after the car was assembled ...
| | #34 (permalink) |
| 2124 Bronze Supporter ![]() Join Date: Jul 2004 Location: Rescue, CA GT40: CAV #80
| Re: Factory powdercoated chassis Remember that if you fasten something to a powdercoated part (chassis or other) that you will need to clean away the coating from between the two pieces as the powdercoat will not allow you to fasten it properly.
__________________ CAV #80, 331 Keith Craft, RBT |
| | #35 (permalink) |
| petek 2 Tenths ![]() Join Date: Sep 2001 Location: KCMO GT40: Not yet...
| Re: Factory powdercoated chassis Couldn't you use some tape discs to cover an area around the holes before spraying the powder coat material? Peal the tape discs off after baking and you'd have fresh surface for the bolts with no powder coat to interfere.
__________________ Pete K. When your memories out number your aspirations you are officially "old." |
| | #37 (permalink) |
| 40bud 8 Tenths ![]() Join Date: Nov 2001 Location: San Francosco a GT40: GTD Finished in
| Re: Factory powdercoated chassis When powder coating aluminium be sure you know the tempratures and time involved and how itmight alter the metallurgy of the ali. Also aluminium oxidizes very rapidly and can lower the adhesion qualities of the powder coat. |
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/rcr-forum-rcr40-rcr70-p4-mkiv/21375-factory-powdercoated-chassis.html | ||||
| Posted By | For | Type | Date | |
| GT40s.com | This thread | Refback | 04-05-07 09:39 PM | |
| GT40s.com | This thread | Refback | 04-05-07 09:19 AM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
