Old 11-03-07, 03:52 PM   #1 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Rep Power: 7 jonathans is just really nice
Access Hole for Front Suspension
I am considering adding two access holes to get at the front lower control arm bolts. The holes would make removal of the bolts for the lower arms much easier. The holes would be a little over 1 inch to clear a 15/16 socket. The proposed location for the holes is indicated in blue on the attached photo. I would think the corner would have enough strength that the removal of material would not weaken it much. What do the rest of you think?
RCR GT40
Build Page: https://home.comcast.net/~jonathanstrain/
jonathans is offline
Old 11-03-07, 05:46 PM   #2 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
Re: Access Hole for Front Suspension
I have opted against the holes. The driver's side nut is hard to get to but not impossible. The access holes would only cut a few minutes off removal of the arm.
RCR GT40
Old 11-03-07, 07:44 PM   #3 (permalink)
Dlampe's Avatar
Dlampe
Silver Supporter
GT40: RCR GT 40
When I assembled everything i put the lower control arms all the way forward in the chassis. Then I used the upper arm to make all the adjustments. I would not want to get to the bolts now! I don't see a reason to ever mess with them again. Don't cut the holes. my .02
Dlampe is offline
Old 11-03-07, 08:16 PM   #4 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 37 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Agreed...this is not a multiple time deal.
Once you have the lower control arm situated , its a one time tighten and leave using the grade eight supplied bolt and nyloc nut.
Its a tight space but not that bad really....considering.
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline
Old 11-04-07, 12:55 AM   #5 (permalink)
jonathans's Avatar
jonathans
Silver Supporter
GT40: RCR
The way I set up the pedal box I thought it was going to be really hard to get at the nut on that side. Once I moved a couple of hoses it was not so bad. I talked myself out of it before you guys did.
RCR GT40
