Go Back   GT40s.com > >
RCR Forum - RCR40/SLC/917/Superlite Aero Sponsored by Race Car Replicas.
Thread Tools Display Modes
Old 2nd February 2010, 11:33 PM   #1
EFNFAST
I Have No Life
Canada
GT40: 917, SLC, Cobra
Bolt torque into aluminum?
For socket head screws tapped into aluminum to hold brackets (i.e., not machine screws you use the screwdriver with), how much torque would you apply to a 1/4x20 bolt?
1/4x20 is usually 10ft-lbs, so that's what I did; then removed 4 of them to sharkhide the area, then put it back and all were stripped (boooo =( ). Then I researchd and it says for aluminum reduce tq values by 40%
So that's around 5-6ftlbs or so.
I knwo ya'll will say "snug with the socket", but is 5-6ft-lbs snug enough for a 1/4 or 5/16 (what I ended up drilling the stripped 1/4s out to)?
EFNFAST is offline   Reply With Quote
Old 3rd February 2010, 12:54 AM   #2
x19.driver's Avatar
x19.driver
Re: Bolt torque into aluminum?
If you don't have too many brackets, you may want to heli-coil your mounting holes. This solved a lot of problems.
x19.driver is offline   Reply With Quote
Old 3rd February 2010, 01:01 AM   #3
EFNFAST
I Have No Life
Canada
it's only 2 brackets that's I'm using the socket heads on. I thought of heli-coiling them .... after I finished drilling them out to 5/16
Old 3rd February 2010, 09:02 AM   #4
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Reduce torque and use an Anti-Seize compound on the threads.. You may not have stripped the threads, but actually had them gall and seize on the bolts.
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 3rd February 2010, 11:30 AM   #5
molleur's Avatar
molleur
GT40: SL-C LS1/930LSD
Alex, try gently running your tap through again. Use anti-seize as Randy suggested.
I torqued mine to 8 ft/lbs. Made many brackets and this is what works for me.
Use a heli-coil as necessary. I had one tapped hole that gave me the same problem.
Chased it out with the tap & it worked fine.
molleur is offline   Reply With Quote
Old 3rd February 2010, 02:39 PM   #6
EFNFAST
I Have No Life
Canada
~everything~ that's gone into the frame has been anti-seized....gobs and gobs of anti-seize everywhere, heh.
I think maybe my inch/lb tq wrench may not be accurate anymore (it's a $30 cheapy one because I couldn't find a quality inch/lb one that wasn't super expensive). I tried chasing (and then re-tapping) the 4 holes, but that didn't do any good.
Good thing it was only a handful I used allen-headed socket bolts on and not the screwdriver/machine screws =)
Old 3rd February 2010, 04:17 PM   #7
molleur's Avatar
molleur
Sounds like heli-coil or nutsert time...
Old 3rd February 2010, 06:03 PM   #8
EFNFAST
I Have No Life
Canada
yea, my 1/4'' tq wrench (in/lb) definately was messed up. I always got the feeling something waas wrong with it, but I wasn't going to pay $60 to calbrate a $25 wrench .... so i bought a new industrial strength one; $150. Much much better (my 30 to 100lbs and 40 to 250lbs are both high quality as well, so no worries there)
So basically using the torque values and not accounting for
- buggered up torque wrench
- anti-seize would lower torque value a bit
- threading into aluminum would lower torque value a lot more
- stainless steel bolt
= I screw myself. hehe, lesson learned, as usual
Btw, in an effort to outhink myself, what I've done now is, instead of using 5/18 stainless steel socket heads (i couldn't find any zinc plated ones locally unless I wanted to pay $50 for a 100pack), i replaced them with 5/16 machine screws, like I'm using ot hold my rubber insulated clips for brakes/electrical. mUahahahaha, can't over-torque those with my screwdriver (unless I tried using a drill to do it, lol!)
Nah, i just drilled the 1/4x20 to 5/16x18
Old 4th February 2010, 03:53 AM   #9
EFNFAST
I Have No Life
Canada
Okay, all buttoned up! It took me 3hrs today, but I found a place that carried plated machine screws in 5/16. Man, those are hard suckers to find, but worth it - install with a screwdriver means Alex can't screw it up and over-torque them, muahahaha
You can't even tell it should have been 1/4; infact, I meant to do 5/16 all the way. Yep, yep, no galled/stripped threads here, it was all part of the master plan
Old 4th February 2010, 09:12 AM   #10
trader
8 Tenths
Great solution you Alex.
trader is offline   Reply With Quote
Forum Jump
Similar Threads
Torque values for AN aluminum fittings molleur All GT40 3 4th November 2009 08:59 PM
5 bolt/6 bolt markg GT40 Tech - Engines/Induction/Exhaust 7 6th September 2007 10:25 PM
Manifold bolt torque specs.... Rick GT40 Tech - Engines/Induction/Exhaust 2 2nd August 2007 12:25 PM
Pressure plate bolt torque?? mike_starling GT40 Tech - Powertrain/Transaxles 1 28th August 2004 01:06 AM
low torque and high torque motors Knighton All GT40 60 4th December 2003 07:34 PM
