Wilwood remote resevoirs
Are you guys using the small reservoirs or the large ones? Is there an advantage/disadvantage to either?
Howard Jones
I used the big ones, Bigger is better.......right? I can't think of any real reason for one or the other, weight? Not much difference really, Room? plenty....
The big ones will require more fluid I guess.. You decide... your car.
Big ones it is :drunk:
I couldn't figure out why Wilwood would provide 2, unless it was just a space issue.
I used the big one's for my brake's and the small one for my clutch slave master.
Alex, I'm using the big ones on my SL-C, lots of room and as Howard said, "Bigger is better". It really does not matter, both sizes are packaged by Wilwood for your convenience when fitting for different applications.
Alex,
I tried both the small and the large ones and just decided that the large ones looked better.
