Hello everybody
Could somebody give me a rough dimension from the top of stock 351W heads (the uppermost edge of the head where the valve cover seats, not from the top of the valve cover) to the bottom of the rear clip on an RCR40?
This does not need to be engineering spec; if you can get me to within 1/2" that would be great. I am trying to sort out some induction ideas and need to have a rough idea of the space I would be dealing with.
I know this distance is going to vary based on how low the engine is mounted, but I'm hoping several of you will chime in so I can establish some sort of range.
Thanks much.
Eric
Thanks much.
Eric
