Has anybody here extended their Dominator ECU DBW wiring harness from one of those companies that manufacturers extension harnesses (i.e., not by not by cutting/splicing wires yourself)
For some reason Holley gives you like 50% less DBW wire (at the gas pedal) than the GMPP ecu box .... no way I can see to make it work with a rear engine car short of either extending the DBW harness, or extending every other wire in the main harness.
I know a harness extension works well enough with the GMPP box, but I can't find anybody whose used one of that harnesses on a Dominator, and, well, I'm not sure I want to be a guinea pig for fear of it working on a test bench, and then going bonkers on the road
