Before I started the SLC, the KOSO unit was working normal. The turn signals, high beams and I could set-up the engine parameter. Since, the start, the KOSO goes through it start-up function then it just shutdowns. I have checking the 12volt and the ground connections and the KOSO is getting power. Has anyone seen this problem and if so what did you do? I will place a call to KOSO tomorrow to see what they think.
