Old 11-24-02, 04:05 PM   #1 (permalink)
patbarry's Avatar
Gold Supporter
GT40: Houston, Texas
ball joints
I need some help here...when I assembled the upper ball joints on the front, they bottomed out just fine. However, whe I try and tighten the lower ball joints, the ball spins in its socket and I am unable to tighten the nut on the upright. This is on both sides. Do I have bad joints, or does anyone have any solutions?
Pat Barry
patbarry is offline
Old 11-24-02, 04:52 PM   #2 (permalink)
3 Tenths
Canada
GT40: Vancouver B.C. Canada
Rep Power: 10 Eric is on a distinguished road
Re: ball joints
Assumming the parts are correct, just clean the threads (run a tap on them if the nut wont go on all the way by hand when the peice is out) then if it is still not going put it together as far as possible then use channel locks to squish the two peices toghether then while holding pressure, tighten the nut, impact gun helps with this but dont over torque it.
Eric is offline
Old 11-24-02, 09:09 PM   #3 (permalink)
patbarry's Avatar
Gold Supporter
Re: ball joints
Robert Logan called earlier, (talk about quick response), and reminded me that I needed to press the stud into the upright. Once I did that with a clamp, the nut tightened down easily. On to the rear upright bearing...
patbarry is offline
