| Re: Fuel Senders - Resistance Problems Ross,
The foam cutting is easy !!!!
Get a pipe slightly larger than the outside of the sender body, sharpen it inside of the pipe (put a chissle style finish ) at one end and once the final position is realised cut the foam with the sharpened pipe. Use a motion similar to that used when lighting a piece of wood with another piece of wood ( place the pipe between the palms of your hands which are in the praying position and rotate the pipe with a little downward pressure. The real trick is to sharpen the INSIDE of the pipe. GOOD LUCK !!!!!
Best wishes,
Robert |
