Old 11-28-03, 05:11 PM   #1 (permalink)
Ron Earp's Avatar
Site Administrator
Leather dash and fitting in car
Hey,
you fellows (Robert, Hersh, and John) that fitted a leather dash in the car how did you do it? There is not enough room between the front of the door and the frame for the dash to go in there, when covered with leather. Also, it seems problematical for the windshield/spyder. Any tips?
Best,
Ron
Ron Earp is offline
Old 11-28-03, 06:43 PM   #2 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Re: Leather dash and fitting in car
Ron, mine fits easily. Something I did that may have helped was to slightly raise the fron of the spyder off the scuttle frame - this gives a little more room for the dash. My spider is attached to my scuttle frame with 8-32 screws and rivnuts. Since the heads of the Rivnuts are slightly raised, I installed a strip of 1/16" thick cork-neoprene gasket material, and I used a hole punch to relieve the gasket material around each Rivnut head.
I got the gasket material from McMaster Carr. I also used it to make gaskets between my fuel sender covers and the side sills.
Mark Worthington is offline
Old 11-28-03, 06:58 PM   #3 (permalink)
Ron Earp's Avatar
Site Administrator
Might work, but I was just looking at the door fitment. If the dash is completely against the frame the door just barely closes. I'll check about pushing it up further.
R
Ron Earp is offline
Old 11-28-03, 09:43 PM   #4 (permalink)
4 Tenths
GT40: Phoenix
Rep Power: 11 John Schneider is on a distinguished road
Ron,
We had no problem with mine. My spider is raised a bit but that was for body fitting. Everything just seemed to line up better that way. I don't recall the doors being a problem and unfortumatly the body is back off the car or I could give you a better idea of how mine went together. One other thing, I'm sure you know, I didn't use RF's door hinges so that may have helped also.
Sorry this doesn't help but atleast you know it is possible.
John
John Schneider is offline
Old 11-28-03, 09:50 PM   #5 (permalink)
Ron Earp's Avatar
Site Administrator
Thanks John, I'll try and but it up further. I did use the RF hinges but I don't think they'll be a problem. They are triple bolted and I am going to tack weld them as per Hershal so they do not slip. If the hinge ever need to be removed a tack weld can be broken relatively easily.
R
Ron Earp is offline
Old 11-29-03, 06:27 PM   #6 (permalink)
Roaring Forties's Avatar
Roaring Forties
GT40: NONE
Rep Power: 0 Roaring Forties is infamous around these parts
Ron,
Use talc powder (raid your children's nappie drawer) to ease the dash into place. The talc is also used to make the rubber door seals easier to slide over. Try it first before you LAUGH !!!!!!!!!
As regards to dashes , we now use a vacuum formed dash and this is a lot cleaner, almost like a production car.
We are compelled by law here in Australia to have a "shock absorbing " material under the leather and this is the ONLY reason we cover them. I have seen many dashes in the UK that were just painted and this gives a great RACE look.
Best wishes,
Robert
Roaring Forties is offline
Old 11-29-03, 06:29 PM   #7 (permalink)
Roaring Forties
GT40: NONE
Ron,
As a secondary note, please consider the use of DOWELS on the door hinges instead of welding. The dowels can be removed easier and this could become useful.
Best wishes,
Robert
