Old 06-19-06, 09:08 PM   #21 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Thanks, Jac, I just figured that out when I installed them.
Mark
347, MoTeC EFI, pin drives, leather, etc.
Mark Worthington is offline
Old 06-19-06, 11:46 PM   #22 (permalink)
561234's Avatar
561234
GT40: CAV #56 347, we
Rep Power: 9 561234 will become famous soon enough
Smile Ford motor mounts
Ford makes a heavy duty motor mount for the mid 80's F150 with small block, they have a bolt thru the 2 pieces of the mount. I have them on my Tiger, they seem to work just fine.
Cav GT 40, 02 Lightning, 65 R model clone, 66 Al Craft Indy Car, 03 SL 500, 03 Triumph Bonneville.
561234 is offline
Old 06-20-06, 10:29 AM   #23 (permalink)
Frank Beuker's Avatar
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
Rep Power: 7 Frank Beuker has a spectacular aura about
Mark i'd find them through google at
http://www.totalcontrolproducts.com/motormounts.html
But i'm making them myself i'll post a picture
Frank
Frank Beuker is offline
Old 06-21-06, 06:25 PM   #24 (permalink)
Frank Beuker
Silver Supporter
Netherlands
GT40: kva
still working on it but this is the beginning
Old 10-16-06, 06:40 AM   #25 (permalink)
GT40: Carins, Australia
Rep Power: 4 burns 01 will become famous soon enough
Re: RF engine mount upgrade
Has anyone used a GT40 Australia mount on a RF chassis? I`m interested to see how it sits on the chassis pad
Burnsy
burns 01 is offline
Old 10-16-06, 08:12 AM   #26 (permalink)
Mick's Avatar
Mick
GT40: Australia
Rep Power: 7 Mick will become famous soon enough
Yes, I never fitted the RF style mount from the begining. the bracket at the rear between the exhaust seem to be a short sighted band aid fix to what was a problem with the engine lurching, not to mention causing problems with fitting the correct exhaust system under the rear clip. I simply modified the rear cross member based on the origonal design and fitted the mount your talking about. I also remade the gear box mounts to reduce any movement in the drive train. This allows the use of rod style shift that works without difficulty. If you need to have a look i have posted pic on 40inches Weblog
40 INCHES
Mick is offline
Old 10-21-06, 07:38 PM   #27 (permalink)
Thanks,Mick, lots of good pic`s on site.... will contact you there.
Regards, Burns.
burns 01 is offline
Old 10-24-06, 07:02 PM   #28 (permalink)
ricadona's Avatar
ricadona
GT40: Roaring Forties
Rep Power: 7 ricadona is on a distinguished road
Hi Burns,
I replaced my standard ford mounts with the GT40Aus mounts recently. Dimensionally they are the same as the ford and fit straight in without any mods.
The reason I used the GT40Aus mounts is because I lowered the gearbox and effectively solid mounted it. Because of this I did not want the engine rotating on the soft ford mounts and then loading up the gearbox cases. The GT40Aus mounts are very rigid limiting any movement and are very well made.
Advantages were that the engine / gearbox is now more level in the car, there is no need for the standard RF restraining rod under the exhaust headers to stop engine movement fwd and back (as mick noted) and it tidys up the mounting arrangement.
Vibration is only noticable on start up, otherwise everything still runs pretty smooth.
It was a good thing I did replace the ford mounts though as the rubber had started to separate. This is after 2500km of track use.
Cheers,
Rick Virago.
RF40 #035
Silver / Black
350rwhp 347 with Stack EFI
Audi 016 with 3.22 CW&P
ricadona is offline
Old 10-24-06, 10:25 PM   #29 (permalink)
ross nicol's Avatar
ross nicol
I have always been under the impression that the reason there was so much angle on the RF/Audi, motor and gearbox, was to get sensible drive shaft angles. Having lowered the rear of your unit Rick, have you now got a lot more angle on the shafts? I haven't solid mounted my 302/ZF but it is pretty well mounted with 2 rear g'box mounts, 2 top g'box mounts onto crossmember
and 2 of the standard rubber engine mounts which don't seemed to get stressed due to the firm mounting of the ZF. I've now done a lot of standing race starts and no problem so far.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline
Old 10-25-06, 09:24 PM   #30 (permalink)
ricadona's Avatar
ricadona
Ross,
Drive shaft angles are not too bad. I have not measured the angle but they look ok with travel still available in the CV's.
My rear end (the car that is) is set up fairly stiff to counter understeer issues so there is inherently minimal rear suspension movement.
Attached photos show : Engine as level as I could get it, Drive shaft looking down on it, and, Drive shaft looking from as far behind as I could get with the rear clip in place.
We are off to NZ tonight for a couple of weeks (yee haa) Only south island but looking forward to it.
Cheers,
Rick Virago.
RF40 #035
Silver / Black
ricadona is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/roaring-forties-gt40s/18471-rf-engine-mount-upgrade.html
Posted By For Type Date
GT40s.com This thread Refback 10-16-06 10:42 AM
Similar Threads
Race Engine Advice Please! Mark Ferrari GT40 Tech - Engines/Induction/Exhaust 28 02-14-07 11:15 PM
Simplified smog in CA BillE All GT40 3 05-01-06 11:51 PM
Engine cutting out Chris Liokos Roaring Forties GT40s 9 11-11-05 05:26 PM
Long term engine storage Brian McCarthy GT40 Tech - Engines/Induction/Exhaust 9 07-15-04 05:48 PM
G50 Trans mount Kalun_D GT40 Tech - Chassis,Brakes,Tires,&Wheels 6 06-21-04 04:06 PM
