Old 08-31-06, 06:04 PM   #1 (permalink)
porsche93's Avatar
porsche93
2 Tenths
GT40: RF Chassie 90
Rep Power: 8 porsche93 is on a distinguished road
Unhappy Getting in Balance
I'll post this question here but it really is for anyone who can help to respond.
I think I I'm between a rock and a hard place. My lump is a SBF that has been taken .030 over so it's 306 CI. The heads are twisted Force and I will be running an 8 stack injection and a medium grind Cam. The block is a 89 vintage that takes a 28 once damper.
My problem is that I do not have an old flywheel to mirror balance the RF flywheel for this motor. I suspect that without that as a starting point I will have to tear the motor down and have the whole thing rebalanced with the RF Flywheel. Before I take that drastic step iIwas looking for alternate suggestions.
Peter
Roaring Forties #80
306CUI, SBF,8 Stack Injection
Motec M800 ECU
Audi 5N with 3.22 Ring and pinion
17 inch Vintage Wheels
Florida Plate # GT40 MK1
porsche93 is offline
Old 08-31-06, 07:24 PM   #2 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Peter, you've answered your own question.
Mark
347, MoTeC EFI, pin drives, leather, etc.
Mark Worthington is online now
Old 08-31-06, 07:47 PM   #3 (permalink)
jac mac's Avatar
jac mac
Rep Power: 18 jac mac has much to be proud ofjac mac has much to be proud of
Peter,
Had the piston,s /rods of your motor been balanced weight for weight prior to assy or even before you bought it.
If so after you remove the crank assy,[turn the motor upside down, remove timing cover etc, place plastic hose over rod bolts to prevent damage, Lift crank out].
Number one rod and piston can be removed from a SB Ford from the bottom in order for the people to compute a bob weight for balancing purposes. Getting that piston back in takes a bit of patience with an old style ring compresser but it can be done.
NB.. Only use this method if you are sure that the pistons/rods have had their weights equalised.
Jac Mac
jac mac is offline
Old 08-31-06, 10:24 PM   #4 (permalink)
iraceone's Avatar
iraceone
Silver Supporter
GT40: Tulsa,OK RF GT40
Rep Power: 10 iraceone is on a distinguished road
Peter I went through the same thing. I tore down my already bal. short block and took the crank , 1 rod/piston, flywheel,balancer and clutch to the machine shop. After they had the motor balanced, they attached the pressure plate , indexed it and fine balanced that to the engine. Mine is 28oz too.Good to "see" you hope all is well.
Dan Weilacher
Roaring Forties
# 091 under
construction
iraceone is offline
Similar Threads
DRB Flywheels - - what balance from the factory daveharris GT40 Tech - Powertrain/Transaxles 6 05-29-06 07:22 PM
Brake balance question gait1969 GT40 Tech - Chassis,Brakes,Tires,&Wheels 8 04-04-06 03:59 PM
Tire sizes for chassis balance kmcgowen GT40 Tech - Chassis,Brakes,Tires,&Wheels 11 11-05-05 02:14 PM
Engine Balance patbarry Roaring Forties GT40s 11 09-22-05 02:20 PM
Flywheel balance Fatal Attraction All GT40 4 03-02-02 12:53 AM
