We use a 75 lb difference in springs front to rear, and depending on your intended use you may consider 275(front)/350(rear)for road use, to 325/400 for road/track use, or even higher for pure track use. Many guys in UK are also using Eiback progressive springs, but these are very expensive and work better with high quality shocks, such as Koni. More detail if you want it. Frank
