I've been wrestling with the best method for balancing the return fuel from an EFI system to the two fuel tanks. My main fear is that one tank will get filled faster than the other.
Solution 1: Build two completely separate systems. Two tanks, filters, pumps, fuel rails, and bypass valves.
Pros: No possible cross-flow.
Cons: A pressure difference from side to side could cause one bank to run lean. Also two points of failure for one system. One fuel pump fails and unless I tell the ECU to only fire on one bank, I DNF.
Solution 2: Fabricate a BIG balance line between the tanks and plumb the return with equal length return lines.
Pros: It'll balance.
Cons: Where to run a 1 inch balance line in an ERA.
And for your added pleasure: plumbing the return lines poses a challenge in the ERA.
Solution 1: Run a 3/8 steel line from the rear to the front and fabricate an "AN" boss in the filler neck.
Best option but a pain to run.
Solution 2: Dump the return to a "T" on the inlet side of the fuel pump.
This brings up an interesting prospect. Most of the circulating fuel is in a loop from the inlet through the pump, around the rails, and through the bypass valve and back to the pump. This fuel will get hotter than if it was circulating to the tank and back.
This is my plight. If any of you have done this and know the "best" way I would appreciate your opinion.
Thanks,
Mark
Thanks,
Mark
