Jim Rosenthal
I would like to hear some thoughts on cam grinds for the engine we've begun building for my GT40. Here are the basics: 302 block, (cleanup bore to 306), forged crank, rods and pistons, rod length 5.40, CR 10:1, AFR heads w/ 165 cc intake runners, and to begin with a 3x2 Weber setup that I am interested to try although it does not look original. (If that doesn't breathe well enough I will go to 4x2 Webers.) It is set up with a plenum and progressive linkage like the old Pontiac 3x2 GTO...I am using a ZF transaxle with 4.11 final drive and a .70 5th gear. I think this engine block will accept either solids or hydraulics, but would have to be retrofit for roller lifters.
I don't know very much about cam selection and I am curious to get info from all the people on the Forum who have built engines for similar cars. I'm making some assumptions, which are as follows: a car that weighs 2400 lbs or less doesn't need a cam grind with huge low-end torque, plus this final drive ratio doesn't require lots of low-end grunt; the ability to rev freely and quickly with a lot of midrange torque is a plus in a GT40; a rev ceiling of 7000 will still give me plenty of room to have fun: the car needs to be street driveable and enjoyable to drive that way.
I would appreciate anyone's thoughts on this; if it has been covered in a prior Forum topic I apologize but this is the best way I know of to get info for these cars and how to set them up. Thank you all in advance for for advice, let me just say that there are a great many things I would not have known of had it not been for this Forum and its' free exchange of ideas.
