Has anyone had luck purchasing a high torque rated transaxle for under $10k?? I can not understand why we are unable to purchase transaxles such as RBT, Quaife, etc. for under $10k.
I realize the G50 is an option, but the gear ratios that I have seen are not really optimal. The first gear that I have seen works out to over 13:1 and the top gear works out to 2.58:1 overall ratios. I would like to have ~10-11:1 first and ~2:1 top gear. It would work if you could change the final drive a bit (shift things down), but all that appears to be available in the aftermarket are different gear ratios (1st through 5th) and not the final drive (stock is 3.44:1). You could change all five gear sets I guess, but the cost would be high I would expect.
For example, G-force can make a magnesium cased transmisson capable of taking 1400 hp for just over $6k. And if you have seen Warren Johnson launch off the line you know it will take some serious abuse. This transmisson is way stronger then any of the above mentioned transaxles. So I add a diff to the case (aka T44) and to cost should jump to $16k to $20k?
Sorry just venting a bit.....
