<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><HR>Originally posted by Bob Putnam -ERA-:
Typical polyester and vinylester resins have "heat distortion temperatures" of between 80C and 100C. Above that temperature, there'll be some noticable change in the matrix's shape - waviness or glass print-through. Epoxies can go much higher, but the best performers are usually in pre-pregs, not hand-laminate resins. We use isophthalic tooling resin - it's got the highest distortion temperature of the non-epoxy laminating resins.
The bottom line is this: Keep exhaust heat away from the body any way you can.<HR></BLOCKQUOTE>
(And) The continued heat cycling leads to further delamination due to the different expansion rates between the resin and the glass fibre. FWIW
