All
Does anyone out there know which wires are which on the standard Ford Cam and Crank angle sensors
The plug on the crank angle sensor has 2 wires on it
Grey/Yellow and Black/Red I would guess that the Grey/Yellow is the Ref wire and the Black/Red is the Zero volt wire
Similarly the Cam angle sensor has 3 wires
Light Blue/Orange (which may be the 8 volt supply)
Dark Blue with spiral orange trace which is probably the sync wire as it is shielded.
and Black/White which seems likely to be Zero Volt.
Can anyone tell me if my assumptions here are correct or not
Regards
John
Regards
John
