Can someone shed some light on the issue and applicability of the Audi 2WD vs AWD transmissions? My 016 gearbox looks like it could've had a rear output shaft, and I have a little plate (Porsche part) to cover the rear of the gearbox. So I guess the first question is, "Can 016 gearboxes from Audi 5000 and Audi 100 Quattro cars be used?"
Second, I have a friend who used to own an Audi S4. He, in turn, has a friend who has a 6-speed transmission out of an S4 with bad synchros, and he has indicated a willingness to sell it to me for a couple hundred bucks. This is the 01E transmission, and I understand that the 01E gearboxes from the S4 have the added advantage of a mechanical pump to allow cooling of the differential lubricant. But everything I've read about the 01E suggests that we would need to use the 2WD version, which was not imported to the US. BTW, I got a quote on a new 2WD 01E gearbox and it was $5,450 plus shipping from Germany. The picture below of Ray Christopher's 01E-equipped GT40 shows what is clearly a provision in the gearbox case for a rear output shaft, which has been covered in this instance. Does anyone know if an AWD 01E gearbox can be set up for use on a GT40?
