Lynn Larsen
Lynn Larsen
For those of you who have ever thought of using these and have researched it, the big question comes down to what pressures do I use? Since many parts houses will not take returns on these, it becomes very important. On my car, I just put two cylinders on the front and two on the rear. They are mounted within 8" of the pivot point. I found that two 20lb cylinders were perfect for the front clip. I can easily lift it with one finger and where ever I stop, it sit exactly there. On the rear, I started with two 35lb cylinders which were entirely too weak. I put two 60lb cylinders on it and it is much better. Not as well controlled as the front, but certainly acceptable as it will drop slowly over the last ten degrees before closing. 80lb cylinders might work, but I am going to stick with the 60lb assists for now. As to length, as long as you stay within the distance of the pivot I mentioned and keep the cylinders near vertical, you should be able to play with length and mouting points and stroke of the cylinders to get the range of motion you need.
