I was about 60 miles from home on Sunday when the alternator light came on. The ammeter showed a 30 amp discharge. The light went off and came on several times, then stayed on. I shut off all the electrical drains I could. Still a 15 amp discharge.
The EFI didn't like it too well, but the car did make it home.
Checking the alernator showed the field to be grounded. So, remove the seats and firewall panel, then removed the alternator. I checked it again out of the car and the field resistance looked fine. Huh?
Turns out that the 2 feet of field wiring from the regulator to the alternator was grounded. So, I cut the wiring harness apart and found the ground wire from the regulator to the alternator had all the insulation melted off it and had melted into the field wire grounding it. Ouch!
Here's what happened. The wire from the alternator to the battery is maybe a 6 Ga. wire. The ground for the alternator (which has to carry the same current load) is normally where it is bolted to the engine brackets.
We powdercoated the alternator and all brackets. Sinced the powder acted as an insulator, the only ground path was the 2 foot wire from the regulator ground to the alternator. It is only 16 or 18 Ga wire, not quite big enough to carry 30+ amps. So, it melted.
I've repaired the wiring and added a 6 Ga gound wire from the ground stud on the alternator to the engine block.
It lasted for 2K+ miles the way it was, but almost made me walk!
Moral of the story.....make sure your alternator has a good ground or you too may be nursing a sick GT40
