Ultimate 289
Brand new fully race prep B50 block with steel main caps
5.506 Titanium rods (1.92 rod ratio)
Custom Arias pistons with titanium wrist pins,10.8 CR with 58cc heads
Custom billet ultralight Crower crank
Zero balanced engine
Ultra rare C6FE GT40 heads with correct titanium IN and EX valve size,professionaly ported by well known haed porter in USA
Custom flat tappet cam designed by Buddy Rawls on heads flow and engine specs
48 IDA Weber manifold
Aviaid GT40 sump pan,etc....
Engine must be viewing for inspection after full break in and dynoed in England at the end od January
Price 40000£ cost over 60000 to build and two years to collect and assemble parts
Bernie [email protected]
Jim Rosenthal
That is indeed the ultimate 289. It may cost more than my entire car- definitely close. Maybe the owner/builder will be kind enough to post the dyno results. It will be interesting to look at. Maybe the most expensive horsepower ever to come out of a 289 block, bar none.
Of course, you could just buy a couple of heads from an Enzo and use them for bookends for the same money....
I agree but after proposed a period Hi po block,my customer preferred a brand new block from FMS and cancelled the project,job is the same and probably more easy to sale
