Flywheel wanted
There are two external ballance weight set ups for flywheels for early and late engines. The car I have had the wrong item, the fix was a Mcleod unit. That results in having a spare flywheel that has run for 10 min also a clutch cover and disc ditto. I can get the date on the flywheel from the Ford casting number if you need more info
