Steering Shaft Support
What is your car using for this design ? I have two 3/4" ball joint rod ends that the main upper shaft passes through and is supported but I don't like the metal to metal contact. Steve
Fran Hall RCR
GT40s Sponsor
This is a standard race car style set up that is both accurate,reliable and strong.....you could use a nylon sleeve for no metal contact and replace one of your rod ends with a nylon bushing and eyelet...
