the other day my GTD had lost all pressure in the clutch pedal. I put it down to it not having been used for a long time (9 yrs) and maybe air in the system. I bled the system and it seemed fine. Went out this morning, no pedal pressure but after one pump of the pedal there was full pressure. I went for a short drive but could feel the pedal loosing pressure (clutch biting point moving further towards the floor) and I just managed to get home. I put this down to maybe more air bubbles and decided to bleed the system again.
On taking off the front of the car, I could see a small puddle of brake fluid that seems to have leaked out of the vent hole on the master cylinder. Again no pressure in the pedal on the first pump. I bled it again to be sure, but there were no air bubbles in the system.
It seems like I may have a problem with my master/and or slave cylinders. Can anyone give me the part numbers for rebuild kits or at least what I need to ask for (all standard GTD I 'spose) and maybe enlighten me as to what the cause is?
by the way, I can see no other leaks of fluid from any other point on the car.
Oh by the way, the clutch has the larger diameter pipe fitted to it (1/4 inch I think)
Simon
Simon
