Oil flow path - or In\'s and Out\'s of plumbing
Ok guys, I'm finally plumbing up the remote oil filter and cooler - need to know which is the in and out (is the center "post" (threaded part) on the block that goes down the center of the oil filter the in or out?
Also, on the oil thrmostat i'm installing (to route the oil around the cooler until its up to temp) they stated to put some light oil on the AN fitting before assembling. I've always used anti-sieze lub because of the aluminun to aluminum contact - have I been doing it wrong? /ubbthreads/images/graemlins/confused.gif
thanks for the inputs!
