Hi,
In the UK, the heater isn't for warmth, but to provide hot demist air to clear the windscreen, so its got to work quickly in cold or wet (i.e. most of British ! ) weather. For this reason mine's plumbed direct through the water pump, so it gets all the engine heat before the thermostat opens. More than this, it uses the thermostat bypass circuit, and runs permanently hot. There is so much heat generated inside the cockpit that the heater matrix with the fan turned off, makes little difference to the generally high levels of discomfort ! Also, this way the heater matrix is self-bleeding as the air is all blown straight through at high velocity before the thermostat opens ( and the air is then extracted from the inlet manifold by a bleed circuit to the header tank. There's plenty of heat for passengers without a heater, its just a question of getting all the huff off the inside of the windscreen. In a hot country, then maybe a heater isn't needed at all. As for running without a thermostat, how do you get the engine to run at the right temperature without a thermostat ? Bearing in mind that 90 percent of engine wear occurs before the engine reaches 85 deg centigrade, why would you NOT fit a thermostat ? If you have to take the thermostat out to get the engine to cool properly, then you've got something else wrong.
Tony.
